October 3, 2024 at 6:56 am
sooriaprakash.kamaraj
SubscriberI have done the erosion analysis coupled with dynamic meshing. I could see the deformed/eroded surface in contour.
I want to export that deformed/eroded surface from ansys in STL file format or any other standard CAD modelling format.
Anyone help me on it?
October 8, 2024 at 1:41 pm
Federico
Ansys EmployeeHello,Â
you can export the xyz coordinates of your surface in ASCII format and convert these point cloud coordinates into a surface using a third party tool.
To export the surface, go to Fluent File > Export > Solution Data. Select ASCII format and the corresponding surface.
