Exporting contour as image
    • imungan
      I just need to export the contour of variables via tui. Is there any possibility to do that? If yes, what is the command of it?
      Thank you
    • Nikhil N
      Try this command: display/save-picture
      This should generate a hardcopy of the active window.
      Thanks!
      Nikhil
    • imungan
      Thank you.
  • The topic ‘Exporting contour as image’ is closed to new replies.
