Export .txt file with element ID and corresponding elastic modulus
    • camilla.gironi4
      Hello everyone,
      i'm working on a Static Structural simulation. I have a named selection scoped with some elements of the mesh. I would like to export a .txt file containing the element ID of these elements and their corresponding elastic modulus. Any suggestion? I tried with some scripts but nothing working at the moment.
      Moreover, a doubt that I have is, if I create a second simulation consecutive to this one, with the same model, is it possible to read the previously saved .txt file and assign the specific elastic modulus indicated in that file to the elements included in the named selection?
      Thank you!
    • erik.kostson
      Hi
      Assuming it is Workbench mech. you are using.
      One way of doing this (get Young’s mod. for mesh/elements) using ACT mechanical scripting is shown here:
      https://discuss.ansys.com/discussion/4481/how-to-get-youngs-modulus-for-each-element-in-the-mesh
      If in APDL then looping over elements and using as below can do the same:
      enow = elnext(enow)
      *GET,mpid,ELEM,enow,ATTR,MAT ! get MP MAT number of el.
      *GET, mpex(ii, 1), EX, mpid ! Store it in array
      For the second part, that would need APDL.
      All the best
      Erik
