3D Design
3D Design
Export to 3D Image bug in Discovery 2021R2
    • Healme
      If you want to export the optimized shape to a 3D Image, make shure that the original body is NOT hidden. If hidden, the export results in an error.
      Please make an export without original body possible in the next release, thanks.
    • Charudatta Bandgar
      Hello Healme
      Let me check this issue on my end, if I face the same issue, I will file a bug ticket for it.
      Can you share a screengrab of the error you are getting?
      Regards.
      • Healme
        Charudatta Bandgar , sorry, my license was busy. That's the error message.
      Hello Healme
      Filed a bug ticket (505839) for this, will let you know as I hear back from the developers.
      Regards.
      • Healme
        Until the bug is fixed, you can add a small, light body at a constraint, but exclude it from the topology optimization. For the export you can then hide the main body. At least one body must be visible.
        Healme Thanks for the workaround.
      Hello Healme
      The bug (505839) is resolved in 2022R1.
      Regards.
  • The topic ‘Export to 3D Image bug in Discovery 2021R2’ is closed to new replies.
