LS Dyna
LS Dyna
Export the Time History of Directional Deformation “maximum” at a node by Scripting
    • jhoanespa07
      Hello, I am new in the world of scripting in Ansys, and I would like to ask you how I could export the data in time of the deformation of a node in Explicit Dynamics by scripting. This is because I want to perform a set of 1000 block simulations and I want to automate the process.
      Thank you very much for your attention.
      "Sorry for my bad English".
    • Chris Quan
      To get the time history of displacement at a node or stress in an element, you can right click on Solution Information to insert point results trackers before starting the solve. You can create a local coordinate system in Tree Outline to assist locating the node/element for the point results trackers.
      Please be aware that scripting is not available in Explicit Dynamics system.
      More information about point results trackers can be found in ANSYS Help. See the screen snapshot below for reference.
  • The topic ‘Export the Time History of Directional Deformation “maximum” at a node by Scripting’ is closed to new replies.
