Export text file for each step
    • nts1209
      Dear Ansys Community
      I have a problem and I need some help
      In my simulation, I use 4 steps for 4 value of force (1000N, 2000N, 3000N, 4000N)
      How can I export the text file for each step. Specifically I want to export text file (normal stress) for each case 1000N, 2000N, 3000N, 4000N respectively
      Thank you very much
      I haven't yet learned to code in APDL, but there are several examples on this site of code that you can look at and use along with the online help, under the section Mechanical APDL.
      One
      Two
      Three
      Here is a blog on how to write to a text file.
  • The topic ‘Export text file for each step’ is closed to new replies.
