February 24, 2020 at 11:18 am
alexmarsh
SubscriberHi all,
I've been investigating FEA updating using an ANSYS Workbench static structural model, and have so far been getting the results out by copy/pasting from the tabular data in the relevant Solution objects. I would like to be able to automate the updating process, however (using the ACT console, as it meshes well with my existing Python code), and can't see a command to output this information. The only way I've found so far is to loop over every timestep, which takes hours to complete each time. Given the data is visible and accessible manually, surely there is a way of accessing and outputting it through a command?
If this requires a command snippet I may need more help, as I have little experience with APDL.
Thanks,
Alex
December 2, 2020 at 5:10 pm
bojandimeski1
Subscriberdid you manage to solve the problem?n -
June 14, 2023 at 2:27 am
Gary Wang
Subscriberplease refer to this tp extract tabular data
https://blog.ozeninc.com/resources/using-python-to-export-tabular-data-from-within-ansys-mechanical
(Using Python to Export Tabular Data from within ANSYS Mechanical)
- The topic ‘Export tabular data in ANSYS Workbench’ is closed to new replies.
5824
