August 19, 2020 at 1:36 am
altoke
SubscriberI'm looking for a way to export selected nodes from my mesh with their ID and coordinates which I can later import into the Polytec Vibrometer measurement software to measure the vibration at exactly these points. nIs there a way to add only export the selected nodes into an STL-File? I only found a way to export the whole mesh to STL or selected nodes into a text file. I'm note sure if the Polytec Software can read the text file. nThank you for your help. n -
August 19, 2020 at 11:53 am
Aniket
Forum Moderatortry inserting a result in the solution branch of the tree for selected nodes and export text file by right clicking on the results.nAlso make sure to turn on node locations in file>optio
-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumnn
August 20, 2020 at 12:55 pm
altoke
SubscriberThanks for your help! nIf it helps somebody else in the future: The Polytec PSV-500 Measuring Software accepts a set of node in the .txt Format. Make sure to include the node location as shown by Aniket. You might need to reformat the .txt file regarding decimals separators. My txt-File hat commas and the polytec software requires points.n
- The topic ‘Export selected mesh nodes for experimental modal analysis’ is closed to new replies.
1598
1386
1242
