Export Report Definition Output from Parameter Table
    • Rahadyan
      Hi everyone, I am Ian
      I was wondering, how to export the report definition output from parameter table properly?
      I use Ansys R2020 academic version
      I have several cases, I make different Boxes for each case. every single case consists of 10-15 design points.
      I do parameter simulation per one box (my step could be wrong, I am new in ansys)
      when I click export CSV file from each box individually, the output data file is merged for every box.
      it is hard to read. could I export the CSV files from one single box? thanks
    • Rahul Kumar
      While setting up the case in Fluent, you can select the option of write to file when defining the report definition. This way, each run will have a unique file written.
    • Rahadyan
      Hi, thank you so much for your answer, i will try that way
      I thought there is another way to collectively collect data from parametric
      thanks
      If you click and drag over the text in the table I think you can copy & past into Excel. Try it as it was a trick we used in R12 when we first got parameters but I've not tried it since.
  • The topic ‘Export Report Definition Output from Parameter Table’ is closed to new replies.
