May 25, 2023 at 8:02 am
SAURAV GAUTAM
SubscriberHow can i export reflectance spectrum for range of wavelength from monitor in fdtd?
thank you
May 25, 2023 at 8:03 am
May 25, 2023 at 5:31 pm
Amrita Pati
Ansys EmployeeHi Saurav,
Please refer to the following video for information on different data export methods.
Plotting and Exporting Data in Ansys Lumerical FDTD — Lesson 5, Part 2Let me know if you have any further questions or if you face any issuses. Thank you!
Amrita -
May 25, 2023 at 6:21 pm
May 25, 2023 at 6:23 pm
Amrita Pati
You are welcome! Are you trying to export the figures? Or are you trying to export the data into a text/MATLAB file? I would also like to add that P is the Poynting Vector.Regards,
AmritaÂ
May 26, 2023 at 5:50 am
SAURAV GAUTAM
Subscriberf_power_norm = f_power_array/f_hemisphere_array*transmission(mname); # get fraction of power in cone, then * monitor transmission, for each frequencny
May 29, 2023 at 4:26 pm
Amrita Pati
Thank you for providing more information. You can write this variable (f_power_norm) into a text file using the write script command.
For example:
write("power.txt",num2str(f_power_norm));It will write the data into a text file called "power.txt", which will be saved in the same directory. I believe the variable would have the power for different wavelengths, but not the wavelength itself. So, you can either add it to the same variable from the monitor and then write the variable. Or you can append the wavelegths at the end of file. Please let me know if you face any issues.
Amrita -
May 30, 2023 at 12:17 pm
SAURAV GAUTAM
SubscriberThank you!!
- The topic ‘Export reflectance intensity for a range of wavelength’ is closed to new replies.
