February 3, 2024 at 11:12 am
Zhihe Wang
SubscriberHi all,
New to Rocky and I have been trying to export the geometry of packed bed particles to .stl (for CFD simulation later) from Rocky 2023R1 with academic license.Â
An approach using prepost script (see the figure below) is described in the webinar Rocky in Action: Particle Bed Reactor (https://www.ansys.com/resource-center/webinar/rocky-in-action-particle-bed-reactor). However, the script isn't there or available from Read-to-Use Script of Customer Portal, as all those links under Customer Portal lead to nowhere.Â
Also tried 5.5.7. Export User Process Geometry Triangles to an STL File of the user manual, that doesn't appear working either.
Would very much appreciate it if anyone knew how to do this through GUI or script, or where to find the script.
Kind regards
Zhihe
February 3, 2024 at 2:15 pm
shahin.maghsoudizand
SubscriberHi
 you can find script file in ROCKY_ADDITIONAL_PACKAGE_2024R1_WINX64.zip in https://download.ansys.com/
ÂÂÂ
February 3, 2024 at 2:59 pm
Zhihe Wang
SubscriberHi Shahin,
Found it finally. Thanks so much!
Kind regards
March 25, 2024 at 12:07 pm
yichang xie
SubscriberCan you tell me where?
March 27, 2024 at 5:22 am
Zhihe Wang
SubscriberHi,
From https://download.ansys.com, you can find Add-On Packages under the version you want to use (say 2024R1), then you can see Additional Package under Ansys Rocky, containing this script.
April 2, 2024 at 8:19 am
yichang xie
SubscriberDo you have an email or other means of communication? I will be grateful!
March 29, 2024 at 4:10 am
yichang xie
SubscriberDo you have an email or other means of communication? I will be grateful if you can!
- The topic ‘Export packed bed and particle geometries to .stl from Rocky for CFD’ is closed to new replies.
5969
1307
