October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeHow can one export only the face of a solid in CAD format?
October 17, 2017 at 9:27 am
Arun Kumar
Ansys EmployeeThis is not directly possible, but user can create a surface from the face using Concept//Surfaces from Faces. And then suppress the solid and finally export the geometry. You should be able to delete the created surface and unsupress original solid.
- The topic ‘Export only the face of a solid in CAD format’ is closed to new replies.
1891
1419
