September 24, 2021 at 12:26 pm
user deleted
SubscriberHello
How can export all total deformation of all mode shapes into one txt file by scripting in Ansys mechanical or any other method?
September 24, 2021 at 1:14 pmVigneswaran Sridharan
Ansys EmployeeHi You can use the ÔÇ£Result SummaryÔÇØ functionality in the 'Worksheet' when you select the Solution from the tree.
You can get the max, min values of deformation for each mode.
Vigneswaran
September 24, 2021 at 2:54 pmAniket Chavan
Forum ModeratorIn addition, you can check multiobject export extension on the Ansys app store.
ANSYS Store Multi Object ExportV1.1 created by ANSYS Inc
It also has source code as well, so you can also modify it to suit your needs.
-Aniket
September 24, 2021 at 6:06 pmuser deleted
SubscriberYes, it worked by multiobject export extension. Thank you
August 22, 2023 at 6:08 amMd_Salem
SubscriberHi @Aniket
is there any way to extract mode shape vectors (eigen vectors) or modal matrix directly from ANSYS ?
Regards
Viewing 4 reply threads- The topic ‘Export mode shapes’ is closed to new replies.
