Electronics
Electronics
Export mean Electric field for all frequencies
    • Rajan_Mistry
      I am simulating a microwave resonator in HFSS using the driven modal solver with a fast frequency sweep. I have used the field calculator to calculate the mean electric field in a block of air just above the resonator. But this only calculates for a single frequency in the sweep. How can apply this to all frequencies in the sweep to export a plot of mean E vs frequency ?n
    • Praneeth
      nAre you trying to evaluate the average field over the defined volume or you want average field over the frequency range?nKindly confirm.nBest Regards,n
    • Rajan_Mistry
      Thanks for your reply.nI want to average the field over the defined volume (which I have done using the field calculator) and then plot this average field against frequency.n
    • Praneeth
      Hi,nDid you try assigning an output variable for the desired quantity? Kindly look into HFSS Help document regarding the definition of output variable.nAll the very best.nBest Regards,n
    • Rajan_Mistry
      That works now, thank younn
Viewing 4 reply threads
  • The topic ‘Export mean Electric field for all frequencies’ is closed to new replies.
