Photonics
Photonics
export gds
    • 2022100400
      I found the method for exporting GDS on the website, but when I tried to export my structure, the result was empty. Why is that?
    • Kirill
      Dear Subscriber,
      1. Please ensure you can reproduce the export for the metalens example as outlined in the GDSII Export Automation article.
      2. Double-check the z-positioning of your layers. It seems none of them actually match your geometry.
      Best regards,
      Kirill
    • 2022100400
      I currently have a very large structure that needs to be exported. Putting it all in one FDTD file would make it very laggy. Now, I want to split the structure into multiple FDTD files and then save them into the GDS file one by one. Each time I save, I need to open the GDS file and save it to a specific location. How should I proceed with this operation?
    • Kirill
      Dear Subscriber,
      You should be able to export your geometries as separate files and later merge them using other software, such as KLayout.
      Best regards,
      Kirill
