September 21, 2024 at 11:39 pm
jfernandez
SubscriberWhen using the erosion option, is it possible to define a differentiated gemetric strain limit for different types of loads, that is, assign different values for tension and compression? For example, 0.2 for tension and 0.3 for compression.
Kind regards, and thank you in advance.
September 23, 2024 at 6:53 am
erik.kostson
Ansys EmployeeHi
Perhaps if forum members can not provide feedback here in this forum (which is about Mechanical, APDL and Implicit),
I would suggest to also post this in the Explicit/LS-Dyna forum (under my Channels).
All the bestÂ
Erik
September 24, 2024 at 11:46 am
jfernandez
SubscriberThank you, Erik, for your response. I will keep looking for options, and if I find it, I will leave it here.
Regards
JF
