Explicit Dynamics body didn’t move
    • dciesielski0103
      I try simulation crash test of locost frame, I modelling frame in SpaceClaim used beams. In explicit Dynamics my frame didn't move. What can i do?
    • erik.kostson
      Hi
      I would suggest to place the wall exactly next to the frame so they are just touching (we do not want to resolve the travel time in explict).
      See here how to set it up (see how the bc/displacement are defined as they allow the car to move towards the wall):
      https://www.youtube.com/watch?v=EhTO0_ovhnA
      All the best
      Erik
      • dciesielski0103
        Hi Erik
        I try move wall to beam but this still didn't work. Maybe I set something wrong.
        All the best
    • erik.kostson
      Hi
      Place the wall a bit closer (gap should be much less than 27778 mm/s*0.001 s ~ 27 mm , so say 5 mm or so).
      Then:
      Can you show the frame displacement at the simulation end time (0.001 s) , because your sim. goes only up to ~1E-8 so perhaps it has not run fully (due to error, etc.) – we want to see if it has actually travelled the gap between the frame and wall.
      Also show the stress contour of the wall to see if it deflects.
      All the best
      Erik
      • dciesielski0103
        Hi
        Wall touch the beam, offset the wall is 5mm from the beam but thickness is 10mm middle so i think they touch the frame. I have something like that only
        All the best
    • mohan.urs
      Hey,
      Can you check this course once and see if you have the setup right. The course is very similar to what you are doing.
      https://innovationspace.ansys.com/courses/courses/explicit-analysis-of-a-chassis/?template=academic
      Let me know how it works out.
      Mohan Urs
    • dciesielski0103
      Hey,
      My solution is convert SpaceClaim geometry to DesingModeler and body start move.
      But I have question how to turn on stress on beams in explicit dynamics?
      Regards
Viewing 4 reply threads
