May 15, 2019 at 5:26 am
edwardbastianh
Subscribernow, i'm using ansys 19.0 for my project. and i got problem in my solution. why chip fromation is not formed in my solution? why there's just red dots all over my workpiece? and about the velocity and feeding, could u tell me how to adjust them? thank you
May 15, 2019 at 6:51 am
Sandeep Medikonda
Ansys EmployeeInitial answer provided here and moved to the Structural Mechanics category
May 15, 2019 at 7:07 am
edwardbastianh
Subscriber thank you for your respond. im using new material, because the engineering data don't have AISI 1045. for the material i'm following this:
.how to show the chip formation? and for the tool rotation / angular velocity and feeding value, im still a lil bit confused. in my assumption for feeding is the value displacement / end time. and the tool rotation, i think i must convert my angular velocity (rpm) to degree /second. or i should put the velocity in initial condition. thank you so much.jpg?width=690&upscale=false)
May 15, 2019 at 7:53 am
Sandeep Medikonda
Ansys EmployeeDecrease the mesh size and increase the feed of the drill bit. There aren't are enough elements in the thickness direction as the cutting is happening. Erosion controls are also important, so make sure they are consistent with whats shown in the video.
I am not sure how the experiments are carried out. But, if I was asked to simulate this, I would define a constant angular velocity and specify a displacement in the appropriate direction. If you specify an initial velocity wouldn't the drill stop rotating after a while due to friction.
May 15, 2019 at 4:38 pm
edwardbastianh
SubscriberThank you so much for your help! i really appreciate it. do you mind to check my works before i start running the simulation again? cause im still have doubt.. please.. i would love to hear more suggestion from you. send me back your email addres, please! thank you in advance!
December 25, 2019 at 2:37 am
0614706
- The topic ‘explicit dynamic simulation’ is closed to new replies.
5969
1307
