December 4, 2023 at 11:30 am
Daniel Dabic
SubscriberHi,
I want to simulate a milling process but i always get a error message "An error occured when the post processor attempted to load a specific result. Please review all messages."Â
I tried to clear all data and simulate one more time, but i got the same result. How can i fix this?Â
best regards,
Daniel -
December 4, 2023 at 2:26 pm
Aniket Chavan
Forum ModeratorHi Daniel,
Have you tried suppressing all results and unsuppressing them one by one to evaluate and check which one is giving issues?
-Aniket
December 4, 2023 at 2:41 pm
Daniel Dabic
SubscriberHi Aniket,
yes i did but every single result gives me the same error message.-
December 5, 2023 at 11:51 am
Aniket Chavan
Forum Moderatorso deleting all results and adding new ones would do the same, I assume?
-Aniket
December 5, 2023 at 2:39 pm
Daniel Dabic
Subscriberyes exactly
December 6, 2023 at 5:10 pm
Chris Quan
Ansys EmployeeThis error message could be caused by various reasons. You may conduct the following checks:
- Uncheck the box "Distributed" and set the number of cores to 1. Then click Solve. If model runs, it means that you need to install MPI tools, for example Intel MPI, before running the model with HPC ("Distributed" box checked).
- If the WB project is stored in a network drive or a shared folder or MS One-Drive, save the project using Save As to a local drive, for example, C drive, and see if the model runs. If yes, you need to run the model in a local drive and then move the project to a safe location after the simulation has finished.
- Check the Solver Output to see if there are any error messages about materials, contacts, boundary conditions, ..., etc.Â
- The topic ‘Explicit dynamic’ is closed to new replies.
5939
1307
