November 9, 2023 at 2:00 am
nurrizqi.2020
SubscriberI have a miniature sports car in 1:10 scale. Then I want to test it in a wind tunnel to get data such as drag force and downforce. However, how do I do a scale comparison of velocity using the Reynolds number as a benchmark?
November 9, 2023 at 9:41 am
dzikrian.d
SubscriberHello, Nur Rizqi
At first, if you want to find the drag force of the real size of the sports car through a wind tunnel test with your miniature car, you have to determine the Reynolds number of the real size by finding out the car's velocity in real case. Then, you apply the same Reynolds number for the velocity in wind tunnel. Hence, the velocity of the wind tunnel test must be 1/10 of the real size case
December 6, 2023 at 10:09 am
Norman Caban
SubscriberTo compare the velocity of a miniature sports car in 1:10 scale with a full-scale car, you can use the Reynolds number as a benchmark. The Reynolds number is a dimensionless quantity that describes the ratio of inertial forces to viscous forces in a fluid flow. It is defined as:
Re=fracrhovLmu
where rho is the density of the fluid, v is the velocity of the fluid, L is a characteristic length scale, and mu is the dynamic viscosity of the fluid.
To maintain the same Reynolds number between the miniature car and the full-scale car, you need to scale the velocity of the miniature car by the ratio of the characteristic length scales. In your case, the characteristic length scale of the miniature car is 1/10 of the full-scale car. Therefore, you need to scale the velocity of the miniature car by a factor of 10 to maintain the same Reynolds number.Reference: https://www.usna.edu/NAOE/_files/documents/Faculty/schultz/uno onlineSchultz,%20Flack%20-%20Reynolds%20Number%20Scaling,%202013.pdf
January 24, 2024 at 1:21 pm
Lysander Apollonius
SubscriberEmbark on an exhilarating betting journey with Pin-Up, the epitome of excellence in online gaming. Revel in the dynamic features designed to cater to your every need, providing an immersive experience like no other. Our https://pinupbetting1.in/withdrawal-and-deposit.php streamlined payment system ensures swift and stress-free transactions, while the rapid withdrawal process lets you savor the taste of victory without delay. Pin-Up, where every bet is an adventure and every win is a celebration.
- The topic ‘Experiments Using A Wind Tunnel’ is closed to new replies.
