Expected Quantity Error Ansys 2023
    • Victor Levin
      I'm importing a txt file into Ansys 2023 Mechanical scripting. I'm trying to assign a cross section to a line and the txt says the number for the outer and inner radius of the circlular tube which I want to put on a line and I keep getting a "expected Quantity, got float" error reading. The code works on Ansys 2021 and 2022. What are some reasons it may not work on 2023?
    • Aniket Chavan
      Can you paste the code you are using here? ideally you should be able to proceed if you define it as quantity, as shown in https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/act_script/MechAPIsSetDiscreteValues_Setting_Output.html
      -Aniket
      Forum Rules & Guidelines
    • erik.kostson
  • The topic ‘Expected Quantity Error Ansys 2023’ is closed to new replies.
