September 9, 2022 at 6:43 pm
David_SY
SubscriberHello,
I have an issue for Workbench with below:
Ansys: 2022R2 and 2022R1
Ubuntu: 20.04I see many other people had the same issue. I followed the answer in Forum but it did not work.
The error is as below:Unhandled exception caught :
System.DllNotFoundException: Ans.QT.dll assembly: type: member:(null)
at (wrapper managed-to-native) Ansys.UI.Toolkit.QTC.Application.ans_qt_Application_setPluginDirectory(intptr,string)
at Ansys.UI.Toolkit.QT.Application.SetPluginDirectory () [0x000d1] in :0
at Ansys.UI.Toolkit.QT.Application..ctor () [0x00006] in :0
at Ansys.UI.Toolkit.QT.UIFactory.newApplication () [0x00000] in :0
at Ansys.UI.Toolkit.UIFactory.newApplication () [0x0000c] in <3d00ca1c00134e6f8cbdeabb60d40546>:0
at Ansys.UI.Toolkit.Application.InstantiateIApplication () [0x00000] in <3d00ca1c00134e6f8cbdeabb60d40546>:0
at Ansys.UI.Toolkit.Application..cctor () [0x0000a] in <3d00ca1c00134e6f8cbdeabb60d40546>:0
--- System.TypeInitializationException: The type initializer for 'Ansys.UI.Toolkit.Application' threw an exception.
at Ansys.UI.UIManager..ctor () [0x00055] in :0
at Ansys.UI.UIManager.get_Instance () [0x00023] in :0
at Ans.Program.Runtime.InitializeSplashScreen () [0x00057] in <533ef4cf2ec54545830ecf48d3de026d>:0
at Ans.Program.Runtime.Initialize (Ans.Program.RuntimeSettings settings) [0x0021a] in <533ef4cf2ec54545830ecf48d3de026d>:0
at Ans.Program.ExecutableBase.Run (Ans.Program.CommandLineParse parser) [0x0000d] in :0
at Ans.Program.ExecutableBase.DoMain (System.String[] args) [0x000be] in :0 -
September 12, 2022 at 11:54 am
DrAmine
Ansys EmployeeÂ
Ansys is not supported on all Ubuntu versions: Platform Support and Recommendations | Ansys
Can you please provide more details on the Ubuntu versions and the kernels installed?
September 12, 2022 at 5:09 pm
David_SY
SubscriberHello,
Ubuntu: Ubuntu 20.04.4 LTS
Kernel: Linux 5.14.0-1049-oem
According to the Platform Support document, Workbench (I am trying to mesh) is supposed to be supported on Ubuntu LTS 20.04.
Thanks.
September 13, 2022 at 3:13 pm
George Karnos
Ansys EmployeeÂ
I believe this to be a problem with prerequisites…
Please check the Linux Installation Guide, Chapter 2. section 2.1. for Required Libraries.
There are tables that list the reuired library packages for Ubuntu (Last column)Verify that they have all been installed.
Hope this helps!
September 14, 2022 at 7:18 pm
David_SY
SubscriberHello,
I installed all prerequisite libraries in the list of Ansys Document, but it still does not work.
Any idea?
September 15, 2022 at 11:22 am
DrAmine
Ansys EmployeeAre you able to launch Fluent or CFX outside the Workbench? Any error messages in the in the installaiton log file?
September 16, 2022 at 8:03 pm
David_SY
SubscriberI installed the following libraries and now the issue seems to have been resolved:
sudo apt install lsbsudo apt install alien
Thank you for your time and help!
September 19, 2022 at 8:44 am
DrAmine
Ansys Employeelsb is always mandatory and thanks for updating the thread! That is very useful!
- The topic ‘Execute Workbech on Ubuntu’ is closed to new replies.
5809
