November 30, 2023 at 4:31 pm
Daniele Giovannone
SubscriberIs possible to extract the values at nodes of the electric field? Or pass from ansys aedt to ansys apdl?
December 4, 2023 at 3:37 pm
Timos
Ansys EmployeeHello, it is possible to export the Electric field values for every node with Fields Calculator. Please visit :
Maxwell Help > Post Processing and Generating Reports > Using the Fields Calculator > Write CommandMaxwell Help > Post Processing and Generating Reports > Using the Fields Calculator > Export Command
- The topic ‘Exctraction of nodal values’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1318
1156
