July 3, 2024 at 2:11 pm
Farah
SubscriberI am running a two-way FSI involving blood and vessel, but I encounter excessive thickness change problem. I can only obtain results when using a very high Young's modulus (10,000 MPa). Despite this, the simulation does not converge consistently; sometimes it converges, and other times it does not. (time step= 0.001)
I want to perform the simulation using actual values for the vessel, which means using a lower Young's modulus, around 0.05 MPa. However, when I do this, the simulation crashes immediately with the following error message: "Element xxx has excessive thickness change".
I am confident that the fluid part of the simulation (Fluent) works well even without FSI, but the structural part keeps crashing when I use the lower Young's modulus. I know that people are simulating blood flow in vessels without any errors, but I am unsure how to fix this issue.
I have seen this question frequently asked by users, but no answer has been provided, so I hope someone can help me resolve this problem. Thanks!
Edit (Rob) - cleaning up posts.
I am running a two-way FSI involving blood and vessel, but I encounter this error "excessive thickness change".
I want to perform the simulation using actual values for the vessel, which means using a lower Young's modulus, around E_Vessel=0.05 MPa. However, when I do this, the simulation crashes immediately with the following error message: "(DP 0) Participant Solution encountered a fatal error. Message: Element 248 has excessive thickness change. Please do not save the project if you would like to recover to the last saved state."
July 8, 2024 at 2:11 pm
Rahul
Ansys EmployeeHello
You might need to refine your mesh or adjust the material properties to ensure they are consistent throughout the simulation.
If you have not already done so, I recommend checking the mesh quality and looking for any abrupt changes in thickness that could be causing the error.
July 8, 2024 at 2:22 pm
Rahul
Ansys EmployeeFor certain two-way FSI coupled analyses, convergence instabilities can be addressed with System Coupling's Quasi-Newton solution stabilization and acceleration method. Improving Coupled Analysis Stability (ansys.com)
July 10, 2024 at 4:35 pm
Farah
SubscriberHi Rahul,
I have tried different elements that are less susceptible to distortion. I checked the materials, and in the papers, they have all defined these properties for the wall, but I still receive an error.
*** ERROR *** CP = 74.062 TIME= 10:32:17
Element 3909 has excessive thickness change.There are four warnings that I will list below, but honestly, I don’t know which part I’m missing. I am just trying a simple FEA to see if it can pass.
*** WARNING *** CP = 1.328 TIME= 10:31:05
Element shape checking is currently inactive. Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.*** WARNING *** CP = 1.578 TIME= 10:31:05
Material number 2 (used by element 8668) should normally have at least
one MP or one TB type command associated with it. Output of energy by
material may not be available.
*** WARNING *** CP = 4.875 TIME= 10:31:07
A reference moment value times the tolerance is used by the
Newton-Raphson method for checking convergence. The calculated
reference MOMENT CONVERGENCE VALUE = 2.228180446E-06 is less than a
threshold. This threshold is internally calculated. You can
overwrite it by specifying MINREF on the CNVTOL command. Check
results carefully.
DISP CONVERGENCE VALUE = 0.2255E-05 CRITERION= 0.5135E-05 <<< CONVERGED
EQUIL ITER 2 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.3668E-03
FORCE CONVERGENCE VALUE = 0.8002E-06 CRITERION= 0.5000E-04 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.1027E-08 CRITERION= 0.5000E-04 <<< CONVERGED
>>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION 2*** WARNING *** CP = 74.062 TIME= 10:32:17
The unconverged solution (identified as time 1 substep 999999) is
output for analysis debug purposes. Results should not be used for
any other purpose.
July 10, 2024 at 2:53 pm
Farah
SubscriberHi Rahul,
Element 3909 has excessive thickness change.There are four warnings that I will list below, but honestly, I don't know which part I'm missing. I am just trying a simple FEA to see if it can pass.
results carefully.
any other purpose.
July 10, 2024 at 4:34 pm
Farah
SubscriberI've also tried Quasi and Explicit technique but encountere with the same error!
July 12, 2024 at 5:19 am
Ashish Khemka
Forum ModeratorHello Farah,
Please see if the following forum thread helps you: Struggling with Convergence in Structural Analysis. Force drop! (ansys.com)
Ashish Khemka
July 23, 2024 at 1:06 pm
Farah
Subscriber*** Update ***
I finally figured out that I needed to address "Stabilization" I've been working on convergence stabilization by adjusting the:
- Under-Relaxation Factor (URF)
- RMS Convergence Target
- Using different structural solvers (mechanical, explicit)
- Step size
- Number of maximum iterations
- Mesh size
Although it's taking a lot of time for the computer to run (like a day or two), I hope this helps you focus on these specific areas rather than trying out other things. I should try to figure out how to make it more efficient.
July 23, 2024 at 2:34 pm
Ashish Khemka
Forum ModeratorThanks a lot, Farah, for sharing the update!
Ashish Khemka
- The topic ‘“Excessive Thickness Change” Error in 2 way FSI’ is closed to new replies.
5824
