March 18, 2026 at 9:21 pm
Changping Yi
SubscriberHi,
I downloaded input files for battery modelling from https://lsdyna.ansys.com/battery/#download. Some of them cannot be run due to different problems.Â
For the input file of Basic_intshort, it shows *** Error 10246 (KEY+246)
   line contains improperly formatted data
   *** Error reading *EM_MAT card.
     At line# 89 of file
     4     1
 *** Error 10450 (KEY+450)
   in keyword command:
     5     2   3.70e7
     At line# 90 of file
For the case of  Basic_socshift,  it shows *** Error 10246 (KEY+246)
     At line# 67 of file
     4     1
   in keyword command:
     5     2   3.70e7
     At line# 68 of file
 For the case of Meshless, it shows *** Error 10307 (KEY+307)
   CHECKING MATERIAL INPUT Part ID= 1
   PART ID 1 has TMID= 0 which does not exist.
   This is PART 22 in the order of input.
   Coupled structural thermal analysis needs to have a thermal material ID defined.There are different errors with other cases. I am using R16 solver, I wonder if these input files are old or other reasons. Thank you!
March 19, 2026 at 8:36 am
ErKo
Ansys EmployeeÂ
HelloÂ
Thanks for letting us know (indeed these examples are old)– much appreciated.Â
For the first (basic_intshort) and second (basic_socshift) example you mention (https://lsdyna.ansys.com/wp-content/uploads/2022/12/basic_intshort.zip — https://lsdyna.ansys.com/wp-content/uploads/2022/12/basic_socshift.zip) – same issue is for the meshless example.
the em.k file should be like below (change that in that em file – format it as needed):
For ref., the main issue is the *EM_MAT_001 keyword. We need to have 5 individual *EM_MAT_001 keywords like shown below (something has changed in recent releases so we can not have all 5 properties under one *EM_MAT_001 card) – I have made a note for us internally about this issue – many thanks for bringing it up.
So the em.k should be like the one here: https://lsdyna.ansys.com/wp-content/uploads/2022/12/basic.zip (at least with respect to using multiple em_mat cards as below)$–EM.k–
*KEYWORD
*INCLUDE
soc.k
$—+—-1—-+—-2—-+—-3—-+—-4—-+—-5—-+—-6—-+—-7—-+—-8
$ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â $
$ Â Â Â Â Â Â Â Â Â Â Â Â Â Â ELECTROMAGNETISM Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â $
*EM_CONTROL
$——–1———2———3———4———5———6———7———8
$   emsol   numls  emdtinit  emdtmax  emtinit   emtend  ncyclFem  ncyclBem
     3                             5000    5000
*EM_CONTROL_TIMESTEP
1,&em_dt
*EM_RANDLES_SOLID
$#  rdlid  rdltype  rdlarea  ccppart  ccnpart  seppart poselpart negelpart
     1     0     2     1     5     3     2     4
$#    q     cq  socinit   soctou   Â
    20.  0.02777   100.0    -444
$#  r0cha   r0dis   r10cha   r10dis   c10cha   c10dis   Â
   0.02    0.02  0.00001  0.00001   500.0   500.0
$#   temp  frtherm   r0toth    dudt   tempu   Â
   25.0     0     1    0.0     0
$# usesocs  tausocs  sicslcid    Â
     0    0.0     0
*EM_RANDLES_SHORT
2,501
*DEFINE_FUNCTION
501
float resistance_short_randle(float time,
               float x_sep, float y_sep, float z_sep,
               float x_sen, float y_sen, float z_sen,
               float x_ccp, float y_ccp, float z_ccp,
               float x_ccn, float y_ccn, float z_ccn)
{Â
 if (time > 600.) {
 if (y_sep < 0.12) {
  if (y_sep > 0.08) {
   return 0.002 ;
  else {
    return -1.;
          }Â
  else {
  return -1. ;
*DEFINE_CURVE
$uVsSoc
444
0,2.8
10,3.655
100,4.15
200,4.15
*EM_ISOPOTENTIAL
$#  isoid  settype   setid   Â
     1     2     1
*EM_ISOPOTENTIAL
     2     2     2
*EM_ISOPOTENTIAL
     3     2     3
*EM_ISOPOTENTIAL
     4     2     4
*EM_ISOPOTENTIAL_CONNECT
$#  conid  contype   isoid1   isoid2    val    lcid  Â
     1     2     1     2    0.05    Â
$*EM_ISOPOTENTIAL_CONNECT
$$#  conid  contype   isoid1   isoid2    val    lcid  Â
$ Â Â Â Â 2 Â Â Â Â 3 Â Â Â Â 2 Â Â Â Â 0 Â Â Â 0.0 Â Â Â Â Â
*DEFINE_CURVE
$currentVsTime
555 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â
0.,-200
20.,-200
*EM_MAT_001
$  em_mid   mtype   sigma   eosId     Â
     1     2   5.88e7
*EM_MAT_001
     2     1
*EM_MAT_001
     3     1
*EM_MAT_001
     4     1
*EM_MAT_001
     5     2   3.7e7
*EM_OUTPUT
$   matS    matF    solS    solF    mesh   memory   timing   d3plot
     2     2     2     2                    0
$    mf2    gmv                       randle
$ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
*ENDÂ
March 19, 2026 at 11:39 am
ErKo
Ansys EmployeeÂ
For the third meshless example (https://lsdyna.ansys.com/wp-content/uploads/2022/12/meshless.zip) it should be (em.k file):
$ Copyright, 2015 DYNAmore GmbH
$ Copying for non-commercial usage allowed if
$ copy bears this notice completely.
$X——————————————————————————
$X
$X 1. Run file as is.
$X Â Â Requires LS-DYNA Beta version 119000 (or higher) with double precisionÂ
$X
$# UNITS: (kg/m/s)Â
$X
*KEYWORD
*TITLE
EM: Fall of a sphere on a 10 cells battery
*EM_CONTROL
     3                              2     2
*EM_CONTROL_CONTACT
1,1,1,1,,,,0.0002
1,&em_dt
*EM_MAT_001
$  em_mid   mtype   sigma   eosId                randletype
    11     1    6.e7                         1
*EM_MAT_001
    12     1                              2
*EM_MAT_001
    13     1                              3
*EM_MAT_001
    14     1                              4
*EM_MAT_001
    15     1    3.e7                         1
*EM_MAT_001
     1     2    1.e7
*EM_MAT_001
     2     2    1.e7
*EM_MAT_001
     3     4    1.e7
*SET_PART
1
1
*SET_PART
2
2
*SET_PART
3
3
*SET_PART
4
4
*SET_PART
5
5
*SET_PART
6
6
*SET_PART
7
7
*SET_PART
8
8
*SET_PART
9
9
*SET_PART
10
10
*SET_PART
20
11,12,13,14,15,16,17,18
19,20,21,22,23,24,25,26
27,28,29,30
*SET_PART
30
31
*EM_CONTACT
1,1,20,30,,,,0.0002
*EM_RANDLES_MESHLESS
$ randleId randlType partSetId  rdlArea
     1     0    Â
$     Q     cQ  SOCinit   SOCtoU
    20.  2.777e-2    100.    -444
$   r0cha   r0dis   r10cha   r10dis   c10cha   c10dis
   0.02    0.02   0.008   0.008    110.    110.
$   temp fromTherm r0ToTherm    dUdT
    25.     0     1     0
$ Â useSocS Â tauSocS Â lcidSocS
     0     0.     0
     2     0    Â
    25.     0     1     0
     0     0.     0
     3     0 Â
    25.     0     1     0
     0     0.     0
     4     0    Â
    25.     0     1     0
     0     0.     0
     5     0    Â
    25.     0     1     0
     0     0.     0
     6     0    Â
    25.     0     1     0
     0     0.     0
     7     0    Â
    25.     0     1     0
     0     0.     0
     8     0    Â
    25.     0     1     0
     0     0.     0
     9     0    Â
    25.     0     1     0
     0     0.     0
    10     0    Â
    25.     0     1     0
     0     0.     0
*EM_ISOPOTENTIAL
$   isoId  setType   setId  randType
     1     2     1     Â
*EM_ISOPOTENTIAL
     2     2     2    Â
*EM_ISOPOTENTIAL
     3     2     3     Â
*EM_ISOPOTENTIAL
     4     2     4     Â
*EM_ISOPOTENTIAL
     5     2     5     Â
*EM_ISOPOTENTIAL
     6     2     6     Â
*EM_ISOPOTENTIAL
     7     2     7     Â
*EM_ISOPOTENTIAL
     8     2     8     Â
*EM_ISOPOTENTIAL
     9     2     9     Â
*EM_ISOPOTENTIAL
    10     2     10     Â
*EM_ISOPOTENTIAL
    11     2     11     Â
*EM_ISOPOTENTIAL
    12     2     12     Â
*EM_ISOPOTENTIAL
    13     2     13     Â
*EM_ISOPOTENTIAL
    14     2     14     Â
*EM_ISOPOTENTIAL
    15     2     15     Â
*EM_ISOPOTENTIAL
    16     2     16     Â
*EM_ISOPOTENTIAL
    17     2     17     Â
*EM_ISOPOTENTIAL
    18     2     18     Â
*EM_ISOPOTENTIAL
    19     2     19     Â
*EM_ISOPOTENTIAL
    20     2     20    Â
*EM_ISOPOTENTIAL
    37     2     37
$*EM_ISOPOTENTIAL
$$   isoId  setType   setId  randType
$ Â Â Â Â 22 Â Â Â Â 2 Â Â Â Â 22
$  connid  connType isoPotId1 isoPotId2   R,V,I    lcid
     1     3     37          0.
     2     5     1     11          1 Â
     3     5     2     12          2
     4     5     3     13          3Â
     5     5     4     14          4Â
     6     5     5     15          5Â
     7     5     6     16          6Â
     8     5     7     17          7Â
     9     5     8     18          8Â
    10     5     9     19          9
    11     5     10     20          10
$$  connid  connType isoPotId1 isoPotId2   R,V,I    lcid
$ Â Â Â Â 2 Â Â Â Â 4 Â Â Â Â 21 Â Â Â Â 22 Â Â Â Â Â Â Â Â Â
$ Â Â Â Â Â Â Â Â Â Â Â Â Â Â SHORT CIRCUIT Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â $
$*EM_RANDLE_SHORT
$$——–1———2———3———4———5———6———7———8
$$ areaType  functId
$ Â Â Â Â 2 Â Â Â 501
*DEFINE_FUNCTION_TABULATED
$#   fid   definition
    502   (thick,res) pair data
$# title
resistanceVsThickSep
         0.        5.e-5
        1.e-3        5.e-5
        3.e-3        5.e-5
         2.        5.e-5
        1.e2        5.e-5
*DEFINE_FUNCTION
501
{Â
 float distCC;
 float distSEP;
 distCC=sqrt(
   pow((x_ccp-x_ccn),2.)+pow((y_ccp-y_ccn),2.)+pow((z_ccp-z_ccn),2.));
 distSEP=sqrt(
   pow((x_sep-x_sen),2.)+pow((y_sep-y_sen),2.)+pow((z_sep-z_sen),2.));
 if (distCC < 0.000117) {
   return resistanceVsThickSep(distSEP) ;
 } else {
  return -1. ;
*EM_OUTPUT
     4     4     4     4                    0
$    mf2    gmv                       randle
$ Â Â Â Â Â Â Â Â Â 1 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 0
*ENDÂ
March 19, 2026 at 12:31 pm
Changping Yi
SubscriberHello ErKo,
  Thank you so much for the prompt response! basic_socshift and basic_intshort work well now. For Meshless, the error message(error 10307) shows a thermal material ID is missing for many parts.Â
   CHECKING MATERIAL INPUT Part ID= 33
   PART ID 33 has TMID= 0 which does not exist.
   This is PART 24 in the order of input.
   Coupled structural thermal analysis needs to have a thermal material ID defined.-
March 19, 2026 at 1:06 pm
ErKo
Ansys EmployeeÂ
Hi – more than welcome – this works for me (MPP dp R16.1):
yes TMID is not defined – one can use tmid for all parts/composite_shell without one (say tmid=1) – you need also to uncomment the thermal.k include in i.k.
Easier alternative one can have a thermal material card with id TMID=0 and that will be assigned to all parts without any TMID assigned :).
(bit of a trick)So use in thermal.k (tmid=0 is the last *MAT_THERMAL_ISOTROPIC):
$   tmid    tro   tgrlc   tgmult    tlat    hlat  Â
     1 7860.0000   0.000   0.000   0.000   0.000
$    hc     tc Â
 460.00000 40.000000
$#   tmid    tro   tgrlc   tgmult    tlat    hlat  Â
     2 7860.0000   0.000   0.000   0.000   0.000
$#    hc     tc Â
 460.00000 40.000000
     3 7860.0000   0.000   0.000   0.000   0.000
$#    hc     tc Â
 460.00000 40.000000
     0 7860.0000   0.000   0.000   0.000   0.000
$#    hc     tc Â
 460.00000 40.000000
All the bestErko
March 19, 2026 at 2:13 pm
Changping Yi
SubscriberÂ
Hi Erko,
yes, it works if it is downloaded from https://lsdyna.ansys.com/wp-content/uploads/2022/12/meshless.zip. it does not work if it is downloaded from https://www.dynaexamples.com/em/battery.  After I ran it, I could not find the temperature in LSPP(v9,11, and13) while it is shown in the presentation at 30:20 (
&t=1298s). I wonder if I need to define any term for output.Â
March 19, 2026 at 2:23 pm
ErKo
Ansys EmployeeÂ
Hi that is great – dynaexamples I can not comment – the one I sent is the official one .
for thermal: you need also to uncomment the thermal.k and *include in the i.k.
Then in the thermal.k file add the below instead of what is there now:
so a thermal material card with id TMID=0 and that will be assigned to all parts without any TMID assigned :).
(bit of a trick)So use in thermal.k (tmid=0 is the last mat with *MAT_THERMAL_ISOTROPIC below):
*KEYWORD
*TITLE
$---+----1----+----2----+----3----+----4----+----5----+----6----+----7----+----8
$ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â THERMAL Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â $
*CONTROL_SOLUTION
$--------1---------2---------3---------4---------5---------6---------7---------8
$ Â Â soln
     2
*CONTROL_THERMAL_SOLVER
$   atype   ptype   solver   cgtol    gpt   eqheat   fwork    sbc
     1     0     11   1.e-06     8    1.0    1.0    0.0
$  msglvl   maxitr   abstol   reltol   omega              tsf
     0    500  1.0e-10   1.0e-4    1.0              1.0
*CONTROL_THERMAL_TIMESTEP
$    ts    tip    its    tmin    tmax   dtemp    tscp    lcts
     0     1. &therm_dt &therm_dt &therm_dt     1.    0.5     0
*INITIAL_TEMPERATURE_SET
$    nid    tempÂ
     0    25.
$    hc     tc Â
 460.00000 40.000000
$#    hc     tc Â
 460.00000 40.000000
$#    hc     tc Â
 460.00000 40.000000
$#    hc     tc Â
 460.00000 40.000000
*END
All the bestErko
March 19, 2026 at 3:41 pm
Changping Yi
Subscriber-
March 19, 2026 at 3:50 pm
ErKo
Ansys EmployeeHello - for sure there is I think some diff. between our model and video :) - me too so not sure why it is.
Erko
5734
