Photonics
Photonics
Example file for Silicon based Single photon avalanche detector (SPAD)
    • sagar
      Is there any example file (charge simulation) available for silicon-based SPAD?
    • Guilin Sun
      As long as the material properties are proper, I believe you can simulate the PAD device. I would like to encourage you to do the simulation with CHARGE. Please refer to the online examples and let me know if you have any questions from the simulation.
    • sagar
      Do you have any example file of Si-based SPAD where the dark current and I-V curves have already been calculated? It would be easy for me to start with.
    • Guilin Sun
      As I mentioned, there is no difference whatever the semiconductor material you use for simulation of such device. Just follow the examples online to set up your simulation and contact us should you have questions.
      https://optics.ansys.com/hc/en-us/articles/6676559298323-SPAD-Secondary-Emission-and-Absorption
      https://optics.ansys.com/hc/en-us/articles/18772400259859-SPAD-dark-count-rate-simulation
      https://optics.ansys.com/hc/en-us/articles/11910437549203-Optical-crosstalk-in-SPAD-due-to-secondary-emission
      https://optics.ansys.com/hc/en-us/articles/360042331634-10-V-Ge-on-Si-APD-with-Si-multiplication
  • The topic ‘Example file for Silicon based Single photon avalanche detector (SPAD)’ is closed to new replies.
