October 10, 2018 at 5:15 pm
maliuzair
I am simulation biomass drying using thermal phase change evaporation-condensation model (eulerian multiphase).
initial conditions:
Biomass initial volume fraction: 0.6, Temperature: 300 K
Air: initial temperature 300k... gradually increasing with time
after initializing, i check contours of static temperature of biomass. It shows 300 k throughout the domain.Â
when i run simulation for 1 time step (or even more), i check the contours. It shows 300 K where biomass is patched and the rest of the domain shows 373 K. Attached pics.Â
Then I tried with the energy equation turned off in the beginning, and later I turned on the energy equation. The instant I turn ON the energy equation, the warning comes..
Temperature limited to 1.000000e+00 in 15337 cells on zone 2 in domain 3
and the area weighted average of biomass-temperature drops to less than 50 K from 300 K.Â
Can someone please address this issue. the temperature should be 300K throughout the domain. I have checked again and again by turning off the evaporation condensation model. when i turn off the model, there is no such problem.
Thanks
October 10, 2018 at 8:39 pm
DrAmine
Ansys EmployeeHow is the phase change defined? Please attach some Screenshots of phase definition and interactions. Bear in mind thermal phase change ist not proper for multiphase multicomponent cases. Moreover check if you have unphysical backflowÂ
October 10, 2018 at 9:19 pm
maliuzair
Subscriber -
October 11, 2018 at 12:24 am
klu
Ansys EmployeeHi,Â
May I know how the condensation will be triggered? Is there any wall thermal boundary condition that continues to take heat out of flow? I remember that Thermal Phase Change model cannot deal with condensation occurring on walls. Therefore please make sure all walls can have only insulated conditions.
October 11, 2018 at 10:15 am
maliuzair
SubscriberHi KLU,
I am not sure if I understood properly. I am just a beginner. the walls are adiabatic.
Besides I have another simple heat transfer model between air, sand and biomass. Both sand and biomass are granular. Initial conditions are 300 K. I let it run for sometime. But it is behaving abnormally. The temperature shouldn't drop below 300 K.
The boundary conditions are adiabatic walls, velocity inlet for air, and Pressure outlet.
Based on this case and the evaporation model case, what do you suggest. Where is the problem? What am I doing wrong.Â
October 11, 2018 at 7:00 pm
DrAmine
Ansys EmployeeThermal phase change model is not proper for multicomponent flow. You need to drive your bulk phase change by means of relative humdity say partial pressure to saturation pressure. You can even use the Lee model but adjust the saturation temperature to fulfill Antoine equation at RH Equal t0 100%. On the other hand you can make use of the Ddpm Model and get advantage of the more accurate heat and mass transfer for DPM for combustion or droplet or multicomponent particle.Â
October 11, 2018 at 7:05 pm
maliuzair
SubscriberThank you sir. I will have a look in to your suggestions.
Meanwhile can you also please address the second issue in this post, i.e. simple heat transfer between air, biomass (granular) and sand (granular). (No mixture)
Thank you and Best regards
October 12, 2018 at 4:35 am
DrAmine
Ansys EmployeeCheck if you have any openings conducting cold flow from the outside due to backflow (at your pressure outlet). Backflow quantities are always stagnation quantities. So if your air is flowing back with 300 K then it would enter with temperature slightly smaller then 300 K depending on compressibility and pressure in neighborhood. Moreover please move to the most actual release: there were some issues which have been fixed and might affect your solution.
October 12, 2018 at 9:17 am
October 12, 2018 at 6:26 pm
DrAmine
Ansys EmployeePlease post the initialization panel here especially temperatures, vof and mass fractions.
October 13, 2018 at 10:00 am
October 14, 2018 at 7:19 am
DrAmine
Ansys EmployeeWhich heat transfer correlation's have been used? Which release are you using ?
October 14, 2018 at 10:14 am
maliuzair
SubscriberSir,
For gas/solid interactions, GUNN
For solid/solid interactions, TOMIYAMA
Version: ANSYS 17.2
Best Regards
October 14, 2018 at 4:38 pm
DrAmine
Ansys EmployeeSo tomiyama is only suitable for interaction with fluids. Is you air compresible? Please use the most current releases as we have enhanced a lot of stuff in the previous versions.
October 17, 2018 at 9:14 pm
maliuzair
SubscriberSir, the air is in-compressible.Â
As far as tomiyama model is concerned, tomiyama has been used in literature for solids-solids. though i ll try with other suitable model.
Can there be anything wrong with the 2 granular phases, since it works perfectly fine with 1 granular phase. What can possibly be wrong?
Best regards
- The topic ‘Evaporation-condensation model’ is closed to new replies.
5794
