Evaluating high frequencies within a structure
    • per.pucher
      Hi everyone,
      I want to evaluate the different modes and mode shapes in a structure (approximate size 1m x 1m x 1m) designed to accurately position micro-mechanical parts (± 200 nm). The machine produces vibrations in the ultrasonic range (around 40 kHz). I need to know whether this excitation can affect the accuracy of the structure.
      Are there specific things I need to watch out for (like types of mesh or mesh size) in order to achieve accurate results at high freuqencies? Do I have to choose an element size which is at least 2 times smaller than the wave length of the 40 kHz ultrasonic wave?
      Thanks in advance for your help.
    • erik.kostson
      Hi
      In general the guideline would be to have about 6 elements (quadratic so say solid186) per wavelength.
      See the course in modal analysis for more info on how to set it all up.
      Thank you
      Erik
