September 27, 2024 at 11:35 amDiogo MartinhoSubscriber
Hey all,Â
I just implemented the Energy equation in my model. It is a twophase model with gas and liquid. Liquid is the primary phase.
And I just implemented source terms on the liquid phase through UDFs. However, I saw that these source terms indeed increase the temperature of the liquid phase, the temperature of the gas phase also increases.Â
I know in real world this makes sense and I quite happy with the results but I do not understand where in the model is the link between phases in terms of the energy equation.Kind regards,Â
September 27, 2024 at 12:45 pmRobForum Moderator
You need to set the HTC in the Phase Interaction panel. Don't leave the default as "none".Â
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
591
544
524
366
