September 28, 2023 at 6:40 pm
September 29, 2023 at 11:14 am
Forum ModeratorWhat is the flow field doing?
September 29, 2023 at 12:17 pm
September 29, 2023 at 12:39 pm
Forum ModeratorOK, and the flowfield?
September 29, 2023 at 2:02 pm
sinan ozbolgili
SubscriberHi, not understand by asking flow field. what should be flow filed ?
September 29, 2023 at 2:04 pm
September 29, 2023 at 2:11 pm
Forum ModeratorWhere is the heat going? What is the fluid velocity? How much gas has been created? If you do some post processing on a converged solution what do you see?
September 29, 2023 at 2:13 pm
sinan ozbolgili
Subscriberno need to give flueid velocity it eubler pool boiling, heat will be transffer from circle tub to water.
Whater will be boiled and bubble will go to [ressure outler
September 29, 2023 at 2:18 pm
Forum ModeratorAnd pictures showing this?
September 29, 2023 at 2:26 pm
sinan ozbolgili
Subscriberyes, actually I already did for tube wall tempreture 379.15 K but when I try for 380.65 I see after waiitng sometimes is starts to not convertage
September 29, 2023 at 2:48 pm
Forum ModeratorAnd without knowing what the flow is doing when it's not converging I can't make any suggestions as to how to fix your problem.
September 29, 2023 at 2:54 pm
sinan ozbolgili
SubscriberIt is tubulant flow
September 29, 2023 at 3:09 pm
Forum ModeratorPictures?
September 29, 2023 at 3:26 pm
September 29, 2023 at 3:29 pm
Forum ModeratorOK, and what is the flow doing? Contour and vector plots might be useful.
September 29, 2023 at 3:42 pm
September 29, 2023 at 3:58 pm
Forum ModeratorOK, so the gas plume rises. That's a good start. How does the velocity look?
September 29, 2023 at 4:03 pm
sinan ozbolgili
SubscriberVelocity also seems okey but as I spefciifef when heat fluxk reach 60 KW it will start to not convertage .
September 29, 2023 at 7:15 pm
sinan ozbolgili
Subscriberdo you have any suggestion ?
September 30, 2023 at 5:31 am
September 30, 2023 at 3:31 pm
October 3, 2023 at 12:31 pm
Forum ModeratorOK, so what is happening to the flow at that point? Also bear in mind I can't download images so if they're not clear I'm guess what's going on.
October 3, 2023 at 1:00 pm
sinan ozbolgili
SubscriberBubble will raise to outlet pressude but it will not cionertage to 10 ^(-4) . It will stay always around 10^(-2) . There will be fluctuation.
Do you think this is hapening becasue of turbulent kinetic energy in inizalation ? Should i make it too low?
October 3, 2023 at 1:05 pm
Forum ModeratorI suspect it's more likely some effect of the boiling.
October 3, 2023 at 1:33 pm
sinan ozbolgili
SubscriberDoes it mean ''normal'' ? no need take any action ?
October 3, 2023 at 2:27 pm
Forum ModeratorPlease elaborate.
October 11, 2023 at 8:47 am
sinan ozbolgili
SubscriberHi Rob,
may I ask for that kinf od analyse which interfacial area need to be selected ?
-ia particle
- ia symmetric
- ia ishii -
October 11, 2023 at 8:57 am
Forum ModeratorCheck the Theory Guide, it should explain what's most suitable for when.
October 11, 2023 at 9:05 am
sinan ozbolgili
Subscribercould not find, there is interfacial area concentration but there is no interfacial area only thats why I am aksing
October 11, 2023 at 9:41 am
sinan ozbolgili
Subscribercould you pelase support ?
October 11, 2023 at 3:13 pm
Forum ModeratorOdd https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v232/en/flu_ug/flu_ug_sec_mphase_using_steps_eulerian.html%23flu_ug_sec_use_bm
- The topic ‘Euler RPI Boiling’ is closed to new replies.
5899
1306
