January 26, 2020 at 6:09 pm
langlinator
SubscriberHi,
I have piece-wise non-linear stress-strain data, that I need to input to Ansys. It seems like the "Multilinear elasticity" model is most suitable, as you can enter piece-wise data. I know this unloads along the original path, and that is not a problem, as I do not need to consider unloading. As Multilinear Elasticity is not available in Workbench, I'm working in MAPDL (unfamiliar for me).
I am having trouble getting the Multilinear Elasticity (MELAS) model to work. I keep getting error messages.
When setting up the MELAS table (via GUI):
Can anyone provide more detail on what this error means?
January 27, 2020 at 12:55 am
Vitaliy_Degtyarev
SubscriberMELA does not seem to be currently supported. You may want to look into plasticity models at this link:Â Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/ans_mat/amp8sq21dldm.html
I usually use the Multilinear Isotropic Hardening model with plasticity similar to the one shown below to describe a nonlinear stress-strain diagram of steel.
Example 4.5: Multilinear Hardening with Plastic Strain
/prep7
MPTEMP,1,0,500 ! Define temperature-dependent EX MPDATA,EX,1,,14.665E6,12.423e6
MPDATA,PRXY,1,,0.3
TB,PLASTIC,1,2,5,MISO ! Activate TB,PLASTIC data table
TBTEMP,0.0 ! Temperature = 0.0
TBPT,DEFI,0,29.33E3 ! Plastic strain, stress at temperature = 0
TBPT,DEFI,1.59E-3,50E3
TBPT,DEFI,3.25E-3,55E3
TBPT,DEFI,5.91E-3,60E3
TBPT,DEFI,1.06E-2,65E3
TBTEMP,500 ! Temperature = 500
TBPT,DEFI,0,27.33E3 ! Plastic strain, stress at temperature = 500
TBPT,DEFI,2.02E-3,37E3
TBPT,DEFI,3.76E-3,40.3E3
TBPT,DEFI,6.48E-3,43.7E3
TBPT,DEFI,1.12E-2,47E3
Vitaliy
January 27, 2020 at 10:19 am
nitinansys1995
Subscribersir , as i want to do soil modelling in ansys workbench . so there are four mechanical model in ansys for soil modelling and defaultly soil properties is given as per cam-clay model . as i added soil to my project i m not getting solution . so i added mohr coloumb properties for soil modelling but again i am not getting any results so sir can you guide me how to know what are the intial steps for this typer of analysis in ansys workbench. here i am attaching some of the images of my work . i am thankful fort your supportÂ
January 27, 2020 at 9:13 pm
Vitaliy_Degtyarev
I'm not an expert in Ansys Workbench nor in soil material modeling, Perhaps, a discussion at this link will help you:Â /forum/forums/topic/soil-modeling/
Vitaliy
January 28, 2020 at 9:49 am
langlinator
SubscriberI don't understand, why would MELA be available in the MAPDL software if it is not supported?
January 28, 2020 at 6:53 pm
Vitaliy_Degtyarev
SubscriberI do not know and I may be wrong, but I do not see MELA as one of the material data table types listed in ANSYS Help at these links: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/ans_cmd/Hlp_C_TB.html, https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/ans_mat/Mp8sasdgh.html
The link below lists TB,MELAS as legacy material properties.https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/ans_arch/mela.html?q=MELA
An article at this link may help you:Â https://www.padtinc.com/blog/using-external-data-to-utilize-legacy-mechanical-apdl-models-in-ansys-workbench/
January 28, 2020 at 7:01 pm
langlinator
SubscriberThank you for the further advice
It is strange that MELAS shows as legacy for you. I am using 2019 R2 student, and when I access the help materials via the links in the software, it shows as a current model:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_mat/mat_multilinelas.html
and also having elements that support it:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_mat/Mp8sasdgh.html
January 28, 2020 at 7:06 pm
langlinator
SubscriberEdit: Somehow I got into the 2020 R1 help, I checked the 2019 R2 help and have the same indications.
When I access the help materials via the links in the software, it shows as a current model:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v194/ans_mat/mat_multilinelas.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v194/ans_mat/Mp8sasdgh.html
PLANE182 (plane strain or axisymmetric), PLANE183 (plane strain or axisymmetric), SOLID185, SOLID186, SOLID187, SOLSH190, SOLID272, SOLID273, SOLID285, PIPE288, PIPE289
January 28, 2020 at 7:23 pm
langlinator
SubscriberResult: despite the error message, I am getting results that are consistent with my input MELAS data using element SOLID185.
January 28, 2020 at 11:21 pm
Vitaliy_Degtyarev
SubscriberYou are right. I'm still using v.19.2 where MELAS is listed as a legacy material model. I see it as a current model in the later ANSYS versions. Sorry about the confusion.
- The topic ‘Errors with Multilinear Elasticity material model’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3947
1415
1272
1119
1015
