TAGGED: ansys-hfss, hfss, HFSS-Linux, install-error, python
April 28, 2023 at 2:14 am
mmaktoom
SubscriberHi,
I have an HFSS 2022 installed on the Linux (Redhat) server, and it's working. Recently, I also installed the HFSS2023, but it is not opening. I re-install it, but I am still getting the same error message. It gives me the following errors. I would appreciate it if someone could help me figure out this issue.
- > Running first-time configuration for [username here]...
 - *** Dependency verification test disabled by default ***
  [ Use 'export ANS_DEPCHECK=1 ; ./ConfigureSoftware.bash --fullconfig' ]
 - Retrieving user settings... Done
 - Applying user settings... Done - The following additional errors were detected:
 /home/tools/HFSS/v231/Linux64/helic/share/python/lib/python3.9/site-packages/h5py/h5g.cpython-39-x86_64-linux-gnu.so (ldd error): /home/tools/HFSS/v231/Linux64/helic/share/python/lib/python3.9/site-packages/h5py/h5g.cpython-39-x86_64-linux-gnu.so: error while loading shared libraries: libhdf5_hl-84bfe2a0.so.200.0.1: ELF load command address/offset not properly aligned
April 28, 2023 at 4:37 am
e23d5804
Subscriberhallo, maybe there are some problems while loading the needed lib and software.
1.do you have give the access right for the software to install with the folder
2.if there is a config file have not be writed, for the common sense, to start a installaition on the linux and unix, it is needed to change the config file
3.if you have removed all the files of the old edition of the software
June 9, 2023 at 4:08 pm
randyk
Forum ModeratorÂ
Hi hedayat99,
You should be able to remove the referenced xxx.cpython-39-x86_64-linux-gnu.so files and remove thier reference in the .filelist file.
ex:
$ cd /home/tools/HFSS/v231/Linux64/helic/share/python/lib/python3.9/site-packages/h5py/
$ mv h5g.cpython-39-x86_64-linux-gnu.so  h5g.cpython-39-x86_64-linux-gnu.so_ORIG
$ cp -p .filelist .filelist_ORIGedit .filelist  (remove the lines referencing the .so files above)
Another option would be skip the dependencies check by not setting ANS_DEPCHECK=1thanks
RandyÂ
November 8, 2023 at 9:58 am
alessandro.de_oliveira_cabral_junior
SubscriberHow could i set ANS_DEPCHECK=0 ?
November 8, 2023 at 4:09 pm
randyk
Forum ModeratorHi Alessandro,
Note that AEDT2023R2 skips the dependency check by default.Â
ANS_DEPCHECK is not normally set and the default value is '0' - resulting in skipping the dependency check.
To force the dependency check, you would set the environment variable before starting AEDT - the technique depends on your shell.ex: BASHÂ -Â export ANS_DEPCHECK=1
ex: CSHÂ Â -Â setenv ANS_DEPCHECK 1Thanks
RandyÂ
November 8, 2023 at 4:13 pm
SubscriberThanks, I'm getting the same problem here, like the program stops running at:
I have no more information, it doesnt seems theres a log of the error. I'm the only one affected so far, other users are able to lunch without a problem. I was able to run hfss on non graphical mode, the solver starts and it completes the simulation, but i cant acess the GUI to see my results! Do you know what could be the source of the problem?
November 8, 2023 at 5:16 pm
randyk
If you are on a shared resource and the only one having issues with AEDT2023R2, then try this:
mv ~/.mw  ~/.mw_back
mv ~/Ansoft/ElectronicsDesktop2023.2 ~/Ansoft/ElectronicsDesktop2023.2_back
Then try AEDT again.
If still failing, eliminate environment variables PATH and LD_PRELOAD
Thanks
Randy-
November 10, 2023 at 9:08 am
SubscriberHi Randyk, thanks a lot! The mv commands solved the problem :)
November 30, 2023 at 4:01 am
mmaktoom
SubscriberThank you, it is resolved now.
- The topic ‘Errors while running the HFSS 2023 on linux server’ is closed to new replies.
