July 19, 2018 at 3:23 pm
Joseph Lim
SubscriberDear all,
Attached are two errors that I encounter when modelling the beam using the Finite Element Method (FEM). May I ask for some suggestions and help with those problems?
The first error is regarding the converge on a solution for the nonlinear problem. May I know why will this happen and how to solve it?
The second error is regarding an internal solution magnitude limit was exceeded. Is that mean that the load applied to the beam was too large or exceed the ultimate load?Â
Thank you in advance.
JosephÂ
July 19, 2018 at 3:44 pm
Sandeep Medikonda
Ansys EmployeeHi Joseph,
In finite element analyses, all the components are expected to be fully constrained to ensure that the applied forces and the internal forces will balance each other out. The reaction force always follows stiffness and constraints, if there is neither of them to resist an applied force, it results in rigid body motion.
When a model is not fully constrained in Static structural analysis, the solver throws out pivoting error, or errors related to a certain degree of freedom (DOF) exceeding limits. Four ways for identifying the unconstrained body are:
1. If the message appears under the WB messages, right click on the message > Go to Object will take you to the part under Geometry Tree.
2. Identify the node based on the node number provided in the error message. In case the node number is not available in the mesh, it must be an internal node created by Mechanical for features such as remote points, or bolt pretension.
3. Perform a modal analysis on the assembly to identify if there are any 0 Hz (or near zero) modes. If such modes are identified, plot the mode shapes for those modes to identify which parts are free floating.
4. Turn on the Newton-Raphson residuals under Solution information prior to running the model and check the contours for residuals, typically when a part is not constrained, the residuals are distributed all over the problematic part.
Possible Solutions:
- Once you identify the part, check how is the part supposed to be held in place in the actual physical application.
- If the internal forces are expected to be self-balancing due to symmetry (e.g., free thermal expansion of parts), then use weak springs (turn it ON under Analysis Settings) or inertial relief for linear models (small deformation, linear materials, linear contacts).
In case the part is to be held in place by contacts:
Linear contacts (bonded and no separation):
- make sure that there are no initial gaps or penetrations between the parts.
- If there are any, manually define pinball radius so that it is larger than the gap/penetration. Also, use MPC formulation if there are no other MPC based constraints in the vicinity.
- Mesh in the contact region is fine enough.
Nonlinear contacts (frictionless, frictional and rough):
- Change the contact type to Bonded to see if that fixes the issue. If it does, proceed to the following steps. If not, check if the steps listed under linear contacts resolve the issue. If yes, then proceed with the following steps. • If gap is negligibly small, consider using the Interface Treatment Option "Adjust to Touch" to close the gap.
- Use a small amount of friction so that part will not slide away during loading.
- In case of force or pressure loading, use smaller initial timestep, increase a pinball radius.
- If the issue persists, define contact stabilization damping (use a small value such as 5e-2).
- In case of internal nodes such a bolt pretension, make sure that there is no conflicting constraint equation based definition (e.g., scoped surface sharing bolt pretension and symmetry conditions).
April 30, 2020 at 7:08 am
sruthyvs
SubscriberI an a newbie to ansys. I need to design a soil pile continuum model in ansys 19.2.I am using a licensed software. I have created a concrete circular single end bearing pile of 500mm Dia and 12m depth in a soil block of 10*10*12 having 5 soil layers of sand and clay..... Including 6 main rebars... 17 top stirrups and... 11 bottom stirrups. I am doing this work to get this settlement analysis in Mohr coulumb model. I found issue in dealing with connections and contacts. I have given bonded connection for steel to concrete, steel rft with stirrups, bw soil layer and frictional contact with coefficient 0.2 for concrete to soil connections. But there occurred problems of overlapping and penetration.... I have just created a default mesh having 0.67m element size with 204484 elements and 981245 nodes with 40 bodies of total... A remote force of - 90Ton but m not getting the total and directional deformation... Saying an unknown error.... And CPU time elapsed..... I am using an i7 lap with 16gb ram and graphics card.... Please help me out to sort out my problem.... I jzt need information on assigning contacts and mesh. I have created contact tool... But some of the contacts are seen inactive and one contact is bonded and closed but has a large amount of penetration and gap? I don't know what it means and how can I solve this.... I just wanna find the soil settlement ie deformation of soil and pile as a whole....
sir could you plz help me to sort out my errors while doing the ansys project.
ANSYS Mechanical Enterprise                     Â
 |  W E L C O M E  T O  T H E  A N S Y S (R) P R O G R A M    |
 *           ANSYS Release 19.2    LEGAL NOTICES            *
 * Copyright 1971-2018 ANSYS, Inc. All rights reserved.      *
 * Unauthorized use, distribution or duplication is           *
 * prohibited.                                                *
 * Ansys is a registered trademark of ANSYS, Inc. or its      *
 * subsidiaries in the United States or other countries.      *
 * See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
 * documentation CD or online help for the complete Legal     *
 * Notice.                                                    *
 * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION      *
 * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY     *
 * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.   *
 * The software products and documentation are furnished by   *
 * ANSYS, Inc. or its subsidiaries under a software license   *
 * agreement that contains provisions concerning              *
 * non-disclosure, copying, length and nature of use,         *
 * compliance with exporting laws, warranties, disclaimers,   *
 * limitations of liability, and remedies, and other          *
 * provisions. The software products and documentation may be *
 * used, disclosed, transferred, or copied only in accordance *
 * with the terms and conditions of that software license     *
 * agreement.                                                 *
 * ANSYS, Inc. is a UL registered                             *
 * ISO 9001:2008 company.                                     *
 * This product is subject to U.S. laws governing export and  *
 * re-export.                                                 *
 * For U.S. Government users, except as specifically granted  *
 * by the ANSYS, Inc. software license agreement, the use,    *
 * duplication, or disclosure by the United States Government *
 * is subject to restrictions stated in the ANSYS, Inc.       *
 * software license agreement and FAR 12.212 (for non-DOD     *
 * licenses).                                                 *
 Release 19.2
 Point Releases and Patches installed: Â
 ANSYS, Inc. Products Release 19.2 Â
 SpaceClaim Release 19.2
 AIM Release 19.2
 Autodyn Release 19.2
 LS-DYNA Release 19.2
 CFD-Post only Release 19.2Â
 CFX (includes CFD-Post) Release 19.2
 Chemkin Release 19.2
 EnSight Release 19.2
 FENSAP-ICE Release 19.2
 Fluent (includes CFD-Post) Release 19.2
 Forte Release 19.2Â
 Polyflow (includes CFD-Post) Release 19.2 Â
 TurboGrid Release 19.2Â
 ICEM CFD Release 19.2 Â
 Aqwa Release 19.2 Â
 Customization Files for User Programmable Features Release 19.2
 Mechanical Products Release 19.2
 Icepak (includes CFD-Post) Release 19.2
 Remote Solve Manager Standalone Services Release 19.2 Â
 Viewer Release 19.2
 ACIS Geometry Interface Release 19.2
 AutoCAD Geometry Interface Release 19.2
 Catia, Version 4 Geometry Interface Release 19.2
 Catia, Version 5 Geometry Interface Release 19.2
 Catia, Version 6 Geometry Interface Release 19.2
 Creo Elements/Direct Modeling Geometry Interface Release 19.2 Â
 Creo Parametric Geometry Interface Release 19.2
 Inventor Geometry Interface Release 19.2
 JTOpen Geometry Interface Release 19.2Â
 NX Geometry Interface Release 19.2Â
 Parasolid Geometry Interface Release 19.2Â
 Solid Edge Geometry Interface Release 19.2Â
 SOLIDWORKS Geometry Interface Release 19.2Â
 ANSYS, Inc. License Manager Release 19.2
         ***** ANSYS COMMAND LINE ARGUMENTS *****
 BATCH MODE REQUESTED (-b)   = NOLIST
 INPUT FILE COPY MODE (-c)   = COPY
 DISTRIBUTED MEMORY PARALLEL REQUESTED
      2 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
   TOTAL OF    2 CORES REQUESTED
 MPI OPTION                  = INTELMPI
 INPUT FILE NAME             = F:SDWORKSPACEMINI-PROJECT ANSYS WORKANSYS WORK (05-04-2020)SOIL-PILE MODEL TRIAL 1SOIL MODEL WITH MANUAL CONTACTS 30-04-2020600mm DIAMETER_ProjectScratchScrF9B3dummy.dat
 OUTPUT FILE NAME            = F:SDWORKSPACEMINI-PROJECT ANSYS WORKANSYS WORK (05-04-2020)SOIL-PILE MODEL TRIAL 1SOIL MODEL WITH MANUAL CONTACTS 30-04-2020600mm DIAMETER_ProjectScratchScrF9B3solve.out
 START-UP FILE MODE          = NOREAD
 STOP FILE MODE              = NOREAD
 RELEASE= Release 19.2        BUILD= 19.2     UP20180808  VERSION=WINDOWS x64
 CURRENT JOBNAME=file0 112:46 APR 30, 2020 CP=     0.172
 PARAMETER _DS_PROGRESS =    999.0000000  Â
 /INPUT FILE= ds.dat LINE=      0
 *** NOTE ***                           CP =      0.297  TIME= 112:46
 The /CONFIG,NOELDB command is not valid in a Distributed ANSYS        Â
 solution. Command is ignored.                                        Â
 *GET _WALLSTRT FROM ACTI ITEM=TIME WALL VALUE= 11.5461111  Â
 TITLE=
 TRIAL-1(600mm dia)--Static Structural (B5)                                  Â
 SET PARAMETER DIMENSIONS ON _WB_PROJECTSCRATCH_DIR
 TYPE=STRI DIMENSIONS=     248       1       1
 PARAMETER _WB_PROJECTSCRATCH_DIR(1) = F:SDWORKSPACEMINI-PROJECT ANSYS WORKANSYS WORK (05-04-2020)SOIL-PILE MODEL TRIAL 1SOIL MODEL WITH MANUAL CONTACTS 30-04-2020600mm DIAMETER_ProjectScratchScrF9B3
 SET PARAMETER DIMENSIONS ON _WB_SOLVERFILES_DIR
 PARAMETER _WB_SOLVERFILES_DIR(1) = F:SDWORKSPACEMINI-PROJECT ANSYS WORKANSYS WORK (05-04-2020)SOIL-PILE MODEL TRIAL 1SOIL MODEL WITH MANUAL CONTACTS 30-04-2020600mm DIAMETERTRIAL-1(600mm dia)_filesdp0SYS-1MECH
 SET PARAMETER DIMENSIONS ON _WB_USERFILES_DIR
 PARAMETER _WB_USERFILES_DIR(1) = F:SDWORKSPACEMINI-PROJECT ANSYS WORKANSYS WORK (05-04-2020)SOIL-PILE MODEL TRIAL 1SOIL MODEL WITH MANUAL CONTACTS 30-04-2020600mm DIAMETERTRIAL-1(600mm dia)_filesuser_files
 --- Data in consistent MKS units. See Solving Units in the help system for more
 MKS UNITS SPECIFIED FOR INTERNAL  Â
 LENGTH       (l) = METER (M)
 MASS         (M) = KILOGRAM (KG)
 TIME         (t) = SECOND (SEC)
 TEMPERATURE  (T) = CELSIUS (C)
 TOFFSET           = 273.0
 CHARGE       (Q) = COULOMB
 FORCE        (f) = NEWTON (N) (KG-M/SEC2)
 HEAT              = JOULE (N-M)
 PRESSURE          = PASCAL (NEWTON/M**2)
 ENERGY       (W) = JOULE (N-M)
 POWER        (P) = WATT (N-M/SEC)
 CURRENT      (i) = AMPERE (COULOMBS/SEC)
 CAPACITANCE  (C) = FARAD
 INDUCTANCE   (L) = HENRY
 MAGNETIC FLUX     = WEBER
 RESISTANCE   (R) = OHM
 ELECTRIC POTENTIAL = VOLT
 INPUT UNITS ARE ALSO SET TO MKS
 *** ANSYS - ENGINEERING ANALYSIS SYSTEM RELEASE Release 19.2    19.2    ***
 DISTRIBUTED ANSYS Mechanical Enterprise                     Â
 00000000 VERSION=WINDOWS x64  112:46 APR 30, 2020 CP=     0.297
         ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
 *********** Nodes for the whole assembly ***********
 *********** Elements for Body 1 "MEDIUM SAND 2" ***********
 *********** Elements for Body 2 "MEDIUM SAND 1" ***********
 *********** Elements for Body 3 "SILTY SANDY CLAY 3" ***********
 *********** Elements for Body 4 "SILTY SANDY CLAY 2" ***********
 *********** Elements for Body 5 "SILTY SANDY CLAY 1" ***********
 *********** Elements for Body 6 "CONCRETE-PILE" ***********
 *********** Elements for Body 7 "TOP STIRRUPS 1" ***********
 *********** Elements for Body 8 "TOP STIRRUPS 2" ***********
 *********** Elements for Body 9 "TOP STIRRUPS 3" ***********
 *********** Elements for Body 10 "TOP STIRRUPS 4" ***********
 *********** Elements for Body 11 "TOP STIRRUPS 5" ***********
 *********** Elements for Body 12 "TOP STIRRUPS 6" ***********
 *********** Elements for Body 13 "TOP STIRRUPS 7" ***********
 *********** Elements for Body 14 "TOP STIRRUPS 8" ***********
 *********** Elements for Body 15 "TOP STIRRUPS 9" ***********
 *********** Elements for Body 16 "TOP STIRRUPS 10" ***********
 *********** Elements for Body 17 "TOP STIRRUPS 11" ***********
 *********** Elements for Body 18 "TOP STIRRUPS 12" ***********
 *********** Elements for Body 19 "TOP STIRRUPS 13" ***********
 *********** Elements for Body 20 "TOP STIRRUPS 14" ***********
 *********** Elements for Body 21 "TOP STIRRUPS 15" ***********
 *********** Elements for Body 22 "TOP STIRRUPS 16" ***********
 *********** Elements for Body 23 "TOP STIRRUPS 17" ***********
 *********** Elements for Body 24 "BOTTOM STIRRUPS 1" ***********
 *********** Elements for Body 25 "BOTTOM STIRRUPS 2" ***********
 *********** Elements for Body 26 "BOTTOM STIRRUPS 3" ***********
 *********** Elements for Body 27 "BOTTOM STIRRUPS 4" ***********
 *********** Elements for Body 28 "BOTTOM STIRRUPS 5" ***********
 *********** Elements for Body 29 "BOTTOM STIRRUPS 6" ***********
 *********** Elements for Body 30 "BOTTOM STIRRUPS 7" ***********
 *********** Elements for Body 31 "BOTTOM STIRRUPS 8" ***********
 *********** Elements for Body 32 "BOTTOM STIRRUPS 9" ***********
 *********** Elements for Body 33 "BOTTOM STIRRUPS 10" ***********
 *********** Elements for Body 34 "BOTTOM STIRRUPS 11" ***********
 *********** Elements for Body 35 "MAIN LONG REBARS 1" ***********
 *********** Elements for Body 36 "MAIN LONG REBARS 2" ***********
 *********** Elements for Body 37 "MAIN LONG REBARS 3" ***********
 *********** Elements for Body 38 "MAIN LONG REBARS 4" ***********
 *********** Elements for Body 39 "MAIN LONG REBARS 5" ***********
 *********** Elements for Body 40 "MAIN LONG REBARS 6" ***********
 *********** Send User Defined Coordinate System(s) ***********
 *********** Set Reference Temperature ***********
 *********** Send Materials ***********
 *********** Create Contact "Frictional - CONCRETE-PILE To Multiple" ***********
            Real Constant Set For Above Contact Is 42 & 41
 *********** Create Contact "Bonded - MEDIUM SAND 2 To MEDIUM SAND 1" *********
            Real Constant Set For Above Contact Is 44 & 43
 *********** Create Contact "Bonded - MEDIUM SAND 1 To SILTY SANDY CLAY 3" *****
            Real Constant Set For Above Contact Is 46 & 45
 *********** Create Contact "Bonded - SILTY SANDY CLAY 3 To SILTY SANDY CLAY 2"
            Real Constant Set For Above Contact Is 48 & 47
 *********** Create Contact "Bonded - SILTY SANDY CLAY 2 To SILTY SANDY CLAY 1"
            Real Constant Set For Above Contact Is 50 & 49
 *********** Create Contact "Bonded - CONCRETE-PILE To Multiple" ***********
            Real Constant Set For Above Contact Is 52 & 51
 *********** Create Contact "Bonded - Multiple To Multiple" ***********
            Real Constant Set For Above Contact Is 54 & 53
 *********** Fixed Supports ***********
 *********** Define Pressure Using Surface Effect Elements ***********
 ***** ROUTINE COMPLETED ***** CP =        6.219
 --- Number of total nodes = 975357
 --- Number of contact elements = 547031
 --- Number of spring elements = 0
 --- Number of bearing elements = 0
 --- Number of solid elements = 202818
 --- Number of condensed parts = 0
 --- Number of total elements = 749849
 *GET _WALLBSOL FROM ACTI ITEM=TIME WALL VALUE= 11.5472222  Â
 *************************   SOLUTION      ********************************
 ***** ANSYS SOLUTION ROUTINE *****
 PERFORM A STATIC ANALYSIS
 THIS WILL BE A NEW ANALYSIS
 LARGE DEFORMATION ANALYSIS
 USE SPARSE MATRIX DIRECT SOLVER
 CONTACT INFORMATION PRINTOUT LEVEL      1
 DO NOT COMBINE ELEMENT MATRIX FILES (.emat) AFTER DISTRIBUTED PARALLEL SOLUTION
 DO NOT COMBINE ELEMENT SAVE DATA FILES (.esav) AFTER DISTRIBUTED PARALLEL SOLUTION
 NLDIAG: Nonlinear diagnostics CONT option is set to ON.
        Writing frequency : each ITERATION.
 DEFINE RESTART CONTROL FOR LOADSTEP LAST
 AT FREQUENCY OF LAST AND NUMBER FOR OVERWRITE IS   0
 DELETE RESTART FILES OF ENDSTEP
 ******************* SOLVE FOR LS 1 OF 1 ****************
 SELECT      FOR ITEM=TYPE COMPONENT=  Â
 IN RANGE       55 TO        55 STEP         1
       147 ELEMENTS (OF    749849 DEFINED) SELECTED BY ESEL COMMAND.
 SELECT     ALL NODES HAVING ANY ELEMENT IN ELEMENT SET.
       488 NODES (OF    975357 DEFINED) SELECTED FROM
     147 SELECTED ELEMENTS BY NSLE COMMAND.
 GENERATE SURFACE LOAD PRES ON SURFACE DEFINED BY ALL SELECTED NODES
 VALUES= 346840.000     0.00000000  Â
 NUMBER OF PRES ELEMENT FACE LOADS STORED =       147
 ALL SELECT  FOR ITEM=NODE COMPONENT=  Â
 IN RANGE        1 TO    975357 STEP         1
    975357 NODES (OF    975357 DEFINED) SELECTED BY NSEL COMMAND.
 ALL SELECT  FOR ITEM=ELEM COMPONENT=  Â
 IN RANGE        1 TO    749849 STEP         1
    749849 ELEMENTS (OF    749849 DEFINED) SELECTED BY ESEL COMMAND.
 PRINTOUT RESUMED BY /GOP
 USE AUTOMATIC TIME STEPPING THIS LOAD STEP
 USE      1 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL DEGREES OF FREEDOM
 FOR AUTOMATIC TIME STEPPING:
  USE    10 SUBSTEPS AS A MAXIMUM
  USE     1 SUBSTEPS AS A MINIMUM
 TIME= 1.0000  Â
 ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
 WRITE ALL ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
  FOR ALL APPLICABLE ENTITIES
 WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE STRS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPEL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPPL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 NONLINEAR STABILIZATION CONTROL:
 KEY=OFF
 *GET ANSINTER_ FROM ACTI ITEM=INT       VALUE= 0.00000000  Â
 *IF ANSINTER_                        ( =  0.00000    ) NEÂ
     0                                ( =  0.00000    ) THEN  Â
 *ENDIF
 *** NOTE ***                           CP =      7.531  TIME= 112:51
 The automatic domain decomposition logic has selected the MESH domain Â
 decomposition method with 2 processes per solution.                   Â
 ***** ANSYS SOLVE   COMMAND *****
 *** WARNING ***                        CP =      7.875  TIME= 112:51
 Element shape checking is currently inactive. Issue SHPP,ON or       Â
 SHPP,WARN to reactivate, if desired.                                  Â
 *** NOTE ***                           CP =      8.375  TIME= 112:52
 The model data was checked and warning messages were found.           Â
 Please review output or errors file ( F:SDWORKSPACEMINI-PROJECT   Â
 ANSYS WORKANSYS WORK (05-04-2020)SOIL-PILE MODEL TRIAL 1SOIL MODEL Â
 WITH MANUAL CONTACTS 30-04-2020600mm                                 Â
 DIAMETER_ProjectScratchScrF9B3file0.err ) for these warning        Â
 messages.                                                             Â
 *** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
     --- GIVE SUGGESTIONS AND RESET THE KEY OPTIONS ---
 ELEMENT TYPE   1 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 KEYOPT(1-12)=   0   0   0   0   0   0   0   0   0   0   0   0
 ELEMENT TYPE   2 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE   3 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE   4 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE   5 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE   6 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE   7 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 HYPERELASTIC MATERIALS. NO SUGGESTION IS AVAILABLE AND NO RESETTING IS NEEDED.
 ELEMENT TYPE   8 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE   9 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  10 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  11 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  12 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  13 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  14 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  15 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  16 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  17 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  18 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  19 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  20 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  21 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  22 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  23 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  24 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  25 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  26 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  27 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  28 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  29 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  30 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  31 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  32 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  33 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  34 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE  35 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE  36 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE  37 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE  38 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE  39 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE  40 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 00000000 VERSION=WINDOWS x64  112:52 APR 30, 2020 CP=     8.516
                      S O L U T I O N  O P T I O N S
  PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D                Â
  DEGREES OF FREEDOM. . . . . . UX  UY  UZÂ
  ANALYSIS TYPE . . . . . . . . . . . . . . . . .STATIC (STEADY-STATE)
  OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . . 273.15  Â
  NONLINEAR GEOMETRIC EFFECTS . . . . . . . . . .ON
  EQUATION SOLVER OPTION. . . . . . . . . . . . .SPARSE           Â
  PLASTIC MATERIAL PROPERTIES INCLUDED. . . . . .YES
  NEWTON-RAPHSON OPTION . . . . . . . . . . . . .PROGRAM CHOSEN Â
  GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRICÂ
 *** WARNING ***                        CP =      9.578  TIME= 112:53
 Material number 55 (used by element 749703) should normally have at   Â
 least one MP or one TB type command associated with it. Output of    Â
 energy by material may not be available.                              Â
 *** NOTE ***                           CP =      9.719  TIME= 112:53
 The step data was checked and warning messages were found.            Â
 messages.                                                             Â
 This nonlinear analysis defaults to using the full Newton-Raphson     Â
 solution procedure. This can be modified using the NROPT command.    Â
 The conditions for direct assembly have been met. No .emat or .erot  Â
 files will be produced.                                               Â
 *** NOTE ***                           CP =     18.500  TIME= 113:02
 The initial memory allocation (-m) has been exceeded.                 Â
 Supplemental memory allocations are being used.                      Â
 Memory resident data base increased from     1024 MB to     2048 MB.
 *** NOTE ***                           CP =     33.484  TIME= 113:17
 Symmetric Deformable- deformable contact pair identified by real      Â
 constant set 41 and contact element type 41 has been set up. The     Â
 companion pair has real constant set ID 42. Both pairs should have   Â
 the same behavior.                                                    Â
 ANSYS will keep the current pair and deactivate its companion pair,   Â
 resulting in asymmetric contact.                                      Â
 Contact algorithm: Augmented Lagrange method
 Contact detection at: Gauss integration point
 Contact stiffness factor FKN                 1.0000  Â
 The resulting initial contact stiffness     0.44683E+10
 Default penetration tolerance factor FTOLN  0.10000  Â
 The resulting penetration tolerance         0.37662E-02
 Max. initial friction coefficient MU        0.20000  Â
 Default tangent stiffness factor FKT         1.0000  Â
 Default elastic slip factor SLTOL           0.10000E-01
 The resulting elastic slip tolerance        0.67866E-03
 Update contact stiffness at each iteration
 Default Max. friction stress TAUMAX         0.10000E+21
 Average contact surface length              0.67866E-01
 Average contact pair depth                  0.37662E-01
 Default pinball region factor PINB           2.0000  Â
 The resulting pinball region                0.75324E-01
 Auto contact offset used to close gap        0.0000  Â
 Initial penetration is excluded.
 Max. Initial penetration 1.331797793E-03 was detected between contactÂ
 element 209964 and target element 216792.                             Â
 You may move entire target surface by : x= -1.327201114E-03, y=       Â
 1.807172058E-18, z= 1.10555704E-04,to reduce initial penetration.     Â
 constant set 42 and contact element type 41 has been set up. The     Â
 companion pair has real constant set ID 41. Both pairs should have   Â
 ANSYS will deactivate the current pair and keep its companion pair,   Â
 The resulting penetration tolerance         0.33540E-01
 The resulting elastic slip tolerance        0.35908E-02
 Average contact surface length              0.35908  Â
 Average contact pair depth                  0.33540  Â
 The resulting pinball region                0.67081  Â
 One of the contact searching regions contains at least 768 target     Â
 elements. You may reduce the pinball radius.                         Â
 Max. Initial penetration 1.218320269E-03 was detected between contactÂ
 element 214856 and target element 206549.                             Â
 You may move entire target surface by : x= -1.016706124E-03, y=       Â
 -3.564265712E-20, z= -6.712770927E-04,to reduce initial penetration.  Â
 constant set 43 and contact element type 43 has been set up. The     Â
 companion pair has real constant set ID 44. Both pairs should have   Â
 Small sliding logic is assumed
 The resulting initial contact stiffness     0.39111E+10
 The resulting penetration tolerance         0.40909E-01
 Default opening contact stiffness OPSF will be used.
 Default elastic slip factor SLTOL           0.50000E-02
 The resulting elastic slip tolerance        0.20307E-02
 Average contact surface length              0.40615  Â
 Average contact pair depth                  0.40909  Â
 Default pinball region factor PINB          0.50000  Â
 The resulting pinball region                0.20455  Â
 Initial penetration/gap is excluded.
 Bonded contact (always) is defined.
 Max. Initial penetration 1.776356839E-15 was detected between contactÂ
 element 218125 and target element 218239.                             Â
 constant set 44 and contact element type 43 has been set up. The     Â
 companion pair has real constant set ID 43. Both pairs should have   Â
 The resulting elastic slip tolerance      &n
- The topic ‘Errors – Reinforced Concrete Beam’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
4062
1487
