June 25, 2023 at 12:53 pm
Gary Wang
SubscriberHi, I encountered an error reminding not enough merory. The machine I used das 128Gb of RAM. And I have checked that during the initial solving, the RAM is under 15% usage. There should be enough RAM. And my model is not that complex with only 19647 elements. I used 4 cores to solve, do I need to allocate RAM for the Ansys? My previous simulation didn't require this.Â
In the Solution Information, it shows that only 2610MB was used for the solver, and the in-core or out-of-core solution didn't take all of them. So why there is an error?
Thanks in advance.Â
June 25, 2023 at 1:00 pm
Gary Wang
SubscriberAdding some materials I find related to this issue:
/forum/forums/topic/there-is-not-enough-memory-for-the-distributed-sparse-matrix-solver-to-proceed-using-the-out-of-core/
/forum/forums/topic/error-37/
https://www.eng-tips.com/viewthread.cfm?qid=446658
https://www.eureka.im/3048.html
/forum/forums/topic/how-to-solve-not-enough-memory-error/
/forum/forums/topic/not-enough-memory-error/
July 5, 2023 at 10:56 am
Gary Wang
SubscriberAny help from the community? Thanks a lot.
July 5, 2023 at 4:56 pm
mrife
Ansys EmployeeHi Gary Wang
There are no errors being shown in the screen shot, just warnings. Check the output prior to the screen shot; there may be a reason given why the solver changed to the out-of-core mode. Guessing due to partial pivoting. Â
July 10, 2023 at 10:14 am
Gary Wang
SubscriberHi Mike,
I didn't capture the full error. want to show the exact RAM usage. Could you help me understand why my 128G RAM is not fully used? And how to take full advantage of my hardware for speedup the simulation?
Best,
Gary
July 10, 2023 at 2:04 pm
mrife
Ansys EmployeeGary
If partial pivoting is activated the charateristics of the stiffness matrix is not known prior to formulation, so the memory allocation needed cannot be known. So out-of-core needs to be used. Â
- The topic ‘[Error]not enough memory for the Distributed Sparse Matrix Solver’ is closed to new replies.
