Electronics
Electronics
Error with NMOS transistor
    • Julio Mariano Geronimo
      Below is the circuitry that I have built:
      I have selected Linear Network Analysis option and I have analyze my circuitry.
      This error pop up:
      I understand that my error is regarding the transistors, but I dont know what should I edit.
      Could it be due to the MOD row not being filled up:
      If yes, what should I insert into the MOD row?
    • dedgar
      HI Julio, The NMOS device requires a suitable model definition (card) to supply the required parameters etc. Model cards are available in the component libraries for different transistor types. If you have a look at the examples for the DIfferentialAmplfier, you can see the setup (bjt in this case)
      Mosfet model cards are found here:
  • The topic ‘Error with NMOS transistor’ is closed to new replies.
