June 14, 2019 at 2:22 pm
pankaj16997
SubscriberHi,
I was able to successfully compile my UDF but then I run into a problem whenever I try entering a parameter into the newly created model(by the UDF).The following is displayed:
Node 999999: Process 9976: Received signal SIGSEGV.
MPI Application rank 0 exited before MPI_Finalize() with status 2
 The fl process could not be started.
The simulation runs fine without the UDF.
Any advice on this matter would be appreciated.
June 17, 2019 at 10:39 am
Forum ModeratorIt means that while the code compiles (ie the syntax is correct) but it's not correct for what Fluent needs. Typical issues are that the data doesn't exist or the maths is wrong (eg code returns 0 or infinity).Â
September 2, 2019 at 11:59 am
stac
Hi guys,
i am facing the same Problem. In my case, i have to define a temperature and pressure dependend viscosity and density.
Right after initialisation, i get the error: The fl process could not be started. Therfore i Initialized it before i did set the user defined viscosity and density. But when i want to start the calculation then i get the folliwing error and fluent collapses:
999999: mpt_accept: Error: accept failed: Invalid argument
Please give me some tips why it doesn't work.
Thank you in advance
September 2, 2019 at 12:07 pm
Forum ModeratorTurn off the UDF density, and see if viscosity fails. I'd look to see how mu_lam is defined.Â
Also, check limitations, historically Fluent didn't like pressure dependent properties that weren't calculated via Ideal Gas or Real Gas inbuilt models: they've been built so as not to mess with the solver numerics. They may work, but be prepared for some convergence problems.Â
- The topic ‘Error while using UDF’ is closed to new replies.
3597
1283
1107
1068
983
