April 29, 2025 at 8:27 am
mysticalmanish11
SubscriberI tried to run ANSYS workbench 2024 Student version but it is giving "An unexpected error has occurred: The type initializer for 'Ansys.Core.Expressions.ExpressionEvaluator' threw an exception." error.
Upon further details it says followingAn unexpected error has occurred: The type initializer for 'Ansys.Core.Expressions.ExpressionEvaluator' threw an exception.
System.MissingMethodException: Method not found: 'System.Collections.Generic.IEnumerable1 Microsoft.Scripting.Utils.ReflectionUtils.GetCustomAttributes(System.Reflection.Assembly, Boolean)'.2 options)
at IronPython.Runtime.Binding.PythonBinder.DomainManager_AssemblyLoaded(Object sender, AssemblyLoadedEventArgs e)
at IronPython.Runtime.Binding.PythonBinder..ctor(PythonContext pythonContext, CodeContext context)
at IronPython.Runtime.PythonContext..ctor(ScriptDomainManager manager, IDictionary
--- System.Reflection.TargetInvocationException: Failed to load language 'IronPython 2.7.4': Method not found: 'System.Collections.Generic.IEnumerable`1Â Microsoft.Scripting.Utils.ReflectionUtils.GetCustomAttributes(System.Reflection.Assembly, Boolean)'.
at Microsoft.Scripting.Runtime.LanguageConfiguration.LoadLanguageContext(ScriptDomainManager domainManager, Boolean& alreadyLoaded)
at Microsoft.Scripting.Runtime.DlrConfiguration.LoadLanguageContext(ScriptDomainManager manager, LanguageConfiguration config)
at Microsoft.Scripting.Runtime.DlrConfiguration.TryLoadLanguage(ScriptDomainManager manager, AssemblyQualifiedTypeName providerName, LanguageContext& language)
at Microsoft.Scripting.Runtime.ScriptDomainManager.GetLanguageByTypeName(String providerAssemblyQualifiedTypeName)
at Microsoft.Scripting.Hosting.ScriptRuntime.GetEngineByTypeName(String assemblyQualifiedTypeName)
at Ansys.Co -
May 2, 2025 at 10:05 am
Rajeshwari Jadhav
Forum ModeratorHi,
What's the release no? Can you rename the Ansys folder (%appadat%) to Ansys.old and try again?
May 28, 2025 at 9:27 am
trinhtt
Subscribertry reinstalling ANSYS and ensure required .NET frameworks are correctly installed.
5824
.png)
