September 8, 2018 at 6:45 pm
September 9, 2018 at 1:16 am
Sandeep Medikonda
Ansys EmployeeHi Ahad,
  Some possible reasons are:
- You may be running out of disk space during the Mechanical solution due to the writing of large solution files. Verify that there is sufficient free disk space on the drive where the solver directory exists.
- You do not have write permissions to the solution directory.
- Files from a previous Workbench session might already reside in the solution directory.
Also, in the structure tree, Go to solution information under the Solution folder. The error should be written there.
So check for these.
Sandeep
September 9, 2018 at 3:11 am
- The topic ‘Error while solving the project’ is closed to new replies.
1650
1386
1242
