Preprocessing
Preprocessing
Error While selecting surfaces to create mid surface in design modeler
    • Sreehari
      I am trying to mesh a very thin surface and I am unable to create a mid surface in Design Modeler as every time I try to select the pair of faces to create a mid surface I am getting the following error " Warning: Face pair outside Selection Tolerance.Suggest: 6.25 e-08m". And I am unable to select the pair of surfaces. Can anybody help me out with this error message, as to what might be the reason and how to rectify it?
    • Keyur Kanade
      what is thickness of your geometry?
      can you please try spaceclaim?
      https://www.youtube.com/watch?v=d4kZ7ikTaT8
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
    • Sreehari
      Is there any way to solve this in design modeller itself, as I am much more used to design modeller, the thickness of the smallest body is 5 e-06m. Could you tell me why I am getting such an error?
      If the body is so thin, do you even need a midsuface?  What if you create surface bodies from the faces on one side of the solid then delete the solid.
    • Sreehari
      I am actually working on a project where I have to mesh a very thin layer on a circuit board, what do you think is the best method for such meshing. I am getting some failed mesh upon simply using the general way
      Is there any specific tutorial or technique for meshing such parts, I would very much like to know about such methods.
    • Sreehari
      All needs to be in hexa mesh as well
      Please insert an image of your geometry.
    • Sreehari
      These are a part of the geometry where I am getting the error, I am getting the failed mesh in mid-layer shown in image above, I have also hidden the top two layer in next image to get a better understanding.
      I am also getting an error message in meshing the mid-layer as follows
      ERROR: The meshing has completed, but some elements are not compliant with the applied shape checking criteria.
      Warning: The MultiZone meshing has completed, but some bad surface elements were created.
      Could you please tell me why I am getting such messages and the reason for failed mesh and how to rectify it
      Thanks in advance
Viewing 7 reply threads
  • The topic ‘Error While selecting surfaces to create mid surface in design modeler’ is closed to new replies.
