December 16, 2018 at 11:45 am
venkatrk84
Subscriberbuild grid error in fluent -
December 16, 2018 at 1:45 pm
raul.raghav
SubscriberThis error is usually caused when you mesh has negative volumes.
To check if you mesh has negative volumes, follow the steps in the screenshot below. If your Determinant has a negative minimum value, you have negative volumes and you would have to fix that before exporting your mesh to Fluent.
If you have negative values, follow the steps in the screenshot attached below:
December 17, 2018 at 4:49 am
Keyur Kanade
Ansys Employeeyes, always check mesh before exporting.
December 17, 2018 at 1:49 pm
venkatrk84
SubscriberThank You Raghav
- The topic ‘Error while reading mesh in Fluent from Icem’ is closed to new replies.
1545
1386
1230
