November 7, 2023 at 10:33 am
za21920
SubscriberDear all,Â
I am getting the fellowing error message when I try to resume my db files. All db files were saved after running same script and input model but for milltiple loading cases. When I try to read the files for post processing, some are resuming perfectly fine without any errors, and for some I get the error bellow. Not sure what is the problem. It seems happing randomly, as sometimes even the files that were resuming fine are not readble anymore. Any ideas on what is the problem? or how to fix it ?
"The program is unable to open file E:\......\loadstep80.db. If the suggestions in the associated error messages immediately   Â preceding and/or following this error message do not help resolve the  file issue, please send the data leading to this operation to your   Â technical support provider, along with the I/O error code of 999 and  Â the system error code of 0, for help in determining the possible    Â reasons as to why this file could not be opened. "Data file E:\...\loadstep80.db has incorrect format, is Â missing READ/WRITE permission, or is empty for RESUME."Â
Thank you!
Zainab Â
November 9, 2023 at 3:45 pm
dlooman
Ansys EmployeeNot sure what could be wrong, but usually postprocessing is done with the rst file using the SET command, not by resuming a db file.
- The topic ‘Error while reading file.db in APDL’ is closed to new replies.
