Preprocessing
Preprocessing
Error while meshing in Ansys Aqwa
    • Aniket Parida
      In Ansys Aqwa I'm facing these errors while meshing. I've tried reducing the element size and using sizing control, but nothing worked.
      I have already done the hydrodynamic diffraction simulation for each element of my assembly and everything just worked fine.
      Error 1 : "The meshing engine has failed to generate a mesh on all faces and surfaces. You may need to reduce the Element Size, or use Mesh Sizing to reduce the local element size on small faces."
      Error 2 : " Some problems occurred during the meshing operation; Workbench has been unable to generate a mesh."
    • Mike Pettit
      Are you able to share a screenshot of your geometry? Can you also try importing the mesh into Mechanical, to see if you can generate a mesh there?
      Mike
  • The topic ‘Error while meshing in Ansys Aqwa’ is closed to new replies.
