April 2, 2020 at 2:57 pm
April 3, 2020 at 7:06 am
baijns
Subscriberwhy nobody is answering??
April 3, 2020 at 2:46 pm
ErKo
Ansys EmployeePeter has made an excellent video where velocities are transferred (imported) from a structure to an acoustic domain.
https://www.youtube.com/watch?v=M_4-H7wEPAk
April 4, 2020 at 10:07 am
baijns
Subscriberhey dear my problem is not with respect to methodology. How to correct the not responding issues.
Please help
Baij
April 6, 2020 at 10:27 am
Aniket
Forum ModeratorCan you please try a simpler model with coarser mesh, to check if the methodology works at your end? I am asking this just to rule out hardware limitations.
-Aniket
April 6, 2020 at 4:18 pm
baijns
SubscriberYes sir it works will lesser data. Actually its my fault that I was importing velocity for all frequency points rather I should import for resonance peaks frequency. I was also having issues with using shell element in modal and harmonic response as it will lead to difficulty in importing the normal velocity. I have resolved the issues a bit.
Moreover I would like to ask one question what will be best method to go for far field acoustics. A radiation boundary , A PML region or an infinite element(Absorption boundary condition). Please tell me about this.
Thanks and Regards
Baij
April 7, 2020 at 3:07 pm
Hui Liu
Forum ModeratorFor large files, you can try using ASI file with APDL command. You can insert a command object with the "ASIFILE,write" and "ASIFILE,read" command lines in the structural and acoustic models. This will really speed up the velocity mapping. See this link for how the commands work:Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_acous/acous_adv_unicou.html?q=asi%20file
April 17, 2020 at 4:37 pm
baijns
SubscriberThanks dear its quite useful
July 23, 2020 at 5:49 pm
HamidSabir
SubscriberHello baijsingh. I have the exact same problem, but I don't know how to use ANSYS APDL. Could you please show me how you finally solved the problem? I have wasted a lot of days with this problem and can't progress. Thanks.Â
July 23, 2020 at 5:58 pm
baijns
SubscriberHamid mail me on singhbaij03@gmail.com. I will try to resolve it ok.
- The topic ‘Error while importing normal velocity’ is closed to new replies.
4838
1587
1386
1242
