March 12, 2021 at 5:47 pm
Isha_Engg
SubscriberI am trying to simulate a coil to calculate B_field, inductance, and ohmic and core losses. I am running Optimetrics so that I get L>=10.5uH. The parameters that have to be automatically varied are core dimensions, air gap, number of turns.nHow to know if the cost function will lead to convergence? What would be a limit on parameterization? nDo we have a rule of thumb that certain number parameter variations would converge? n I am getting errors: separate operation failed due to lump count inconsistency. found 18 lumps instead of the expected 16 lumps. What does this error mean?nAre the number of parameters too many to vary to achieve the desired optimization? n -
March 19, 2021 at 6:32 am
NKC
Forum ModeratornAre you parameterizing the values in UDPs?nIn that case, can you check if the results are really getting affected by the error? Are you able to successfully complete the simulation?nMostly this error has no significance and may not affect the results.nnRegardsnNavya,nn -
March 22, 2021 at 11:25 am
Isha_Engg
Subscriber,nYes, the simulation successfully completes now. I used the heal function and the error is no more there. The unhealed and the healed geometry gives the same results. But what is the meaning of this error?nRegards,nIshan -
March 31, 2021 at 11:21 am
NKC
Forum ModeratornIt's a known display bug and it has no significance.n
- The topic ‘Error when using Optimetrics’ is closed to new replies.
Ansys Innovation Space
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1461
1272
1124
