Error when setting Fluent fuel-cell module parameters
    • ljjan
      When trying to apply parameters for the fuel cell module on ansys fluent I am receiving the following error. Any suggestions would be helpful
      Error: GENERAL-CAR-CDR: invalid argument [1]: improper list
      Error Object: #f
      That generally means you've missed a setting somewhere so a required field is blank. Go through all the boundary, material property and model settings and check they're valid.
      Edit: moving to Fluids.
  • The topic ‘Error when setting Fluent fuel-cell module parameters’ is closed to new replies.
