Electronics
Electronics
Error when running Maxwell using Pyaedt
    • Jelte van Luenen
      When running Ansys Maxwell using Pyaedt, I get thousands of these errors. The errors themselves are not really a big issue however I also sometimes get a pop-up with a warning: Testing not enabled. This pop-up blocks any further simulations that are executed by Pyaedt. How do I enable the testing feature or get rid of these messages/pop-ups?
    • chinmay.telkikar
      Thank you for reaching out to the Ansys learning forum.
      Please note that the queries related to PyAEDT cannot be discussed in this forum as there is a dedicated forum. Kindly reach out to - Ansys Developer Portal | Ansys Developer Portal.
      I hope this helps.
      Thanks,
      Chinmay
    • Jelte van Luenen
      Thank you, I will post my question there.
      Just to check, as far as you know there is no 'testing feature' that can be enabled in the GUI of Maxwell?
  • The topic ‘Error when running Maxwell using Pyaedt’ is closed to new replies.
