Preprocessing
Preprocessing
Error when replacing the geometry
    • Stat
      Hi everyone,nA problem that I occasionally meet when running static structural analysis is when I try to replace the geometry of the model. Whether I replace a part of the geometry with a new one or the whole geometry, while the new geometry seems to be loading up, when the loading is over, the geometry does not appear on mechanical and has question-marks under the Geometry sector.nDoes anyone know the reasoning behind this and are there any suggestions?n
    • Karthik Remella
      Administrator
      Please take a look into the geometry and see if the Material Property values are assigned properly.nIf this does not help, please take a screenshot and post it here in your post so can help you.nThanks.nKarthikn
    • Matthias Duve
      Hi, have a similar issue.
      I want to replace only one geometry (part) in an assembly in mechanical. I only seem to be able to replace the whole assembly with the standard prompts. If I do so, all external points, connections, joints eg only have question marks on them afterwards and won´t work. Event on the parts that are exactly the same than before.
      Any ideas how to solve this?
      Thanks a lot!
  • The topic ‘Error when replacing the geometry’ is closed to new replies.
