September 22, 2023 at 5:10 pm
September 25, 2023 at 7:14 pm
George Karnos
Ansys EmployeeI believe this looks like there is a font issue.
Can you check the following:
First, ensure that Tahoma font is installed on your machine.Also, try running when the language is set to English
September 25, 2023 at 9:00 pm
amorotoedu
SubscriberWhat do you mean with "on your machine" ? I do have Tahoma font in Word.
Could you be more especific on the steps to follow ?
Regards
September 25, 2023 at 9:10 pm
George Karnos
Ansys EmployeeCan you translate the first line into english
What operating system are you using.
A way to see your installed fonts is through Control Panel. In Windows 10, go to Control Panel > Fonts."On your machine" refers to the machine where you are trying to run and receivng the error.
You can also try:
Open Windows file explorer and go to:
%APPDATA%|Ansys
You will see a directory v232 or a number that corresponds to the version you are running.
Rename that directory to v232.old
Try to run again. -
September 25, 2023 at 9:22 pm
amorotoedu
SubscriberFirst line says: font "tahoma" is not compatible with the style "regular". And I do have Tahoma installed in my computer, I can use it in Office Word.
My computer is running Windows 10 Home 22H2.
September 26, 2023 at 3:20 pm
George Karnos
Ansys EmployeeAre you running locally or are you running through a terminal window on another machine and displaying on your Windows machine?
September 26, 2023 at 3:40 pm
amorotoedu
SubscriberI am running locally in a Windows 10 Home 22H2 laptop.
- The topic ‘Error when opening Workbench 2023 R2’ is closed to new replies.
6294
