August 1, 2024 at 2:20 am
n01469239
SubscriberHello Guys,Â
I am trying to mesh a symmetric enclosure with a Heat Generation. The mesh is an automatic mesh on the fluid volume and the solid bodies that are inside the enclosure I continue to get these three errors:Â
- error: Â The mesh translation to Fluent failed due to non-conformal, duplicate, or degenerate mesh elements.
- warning: All cell zones in Fluent may be automatically set to Fluid.
- warning: Some boundaries of protected topologies have been defeatured. Â Right-click on this message and select "Show Problematic Geometry" to see the affected edges.
I have continued trying ways to fix them, but they have come to no avail. I have found other forum posts about this error and have tried the solutions in those posts. The two solutions I have found are "make sure you share topology shared correctly" and "make sure you do not have any connections". The two questions I have in response to those solutions are:Â
- How do I correctly complete those two tasks
- How do I make sure that I have done them correctlyÂ
If there are other solutions and any help is appreciated.Â
The pictures of my problem are attached
August 8, 2024 at 5:48 am
Keyur Kanade
Ansys EmployeeThis could be sizing issue. Please use different sizes than default.Â
Please check following videos
Ansys Meshing Sizing:
https://www.youtube.com/watch?v=w4q6q8nKF3UDM Share topology:
https://www.youtube.com/watch?v=IO4ZtwZdD2ISpaceClaim Share topology:
https://www.youtube.com/watch?v=h43E1YO1LiMAnsys Meshing: Meshing Methods:
https://www.youtube.com/watch?v=nEOC8rDnnRoÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
5694
1891
1419
