January 24, 2024 at 10:28 am
fabio.dinatale
SubscriberHello,
we are facing the following problem: when we try to launch Anys Fluent in parallel mode using Intel MPI through terminal on an Ubuntu server, i.e. when we launch this command:
fluent 3d -g -t4 -mpi=intelthen, the program crashes with the following error message:
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = RANK 0 PID 154004 RUNNING AT servername = KILLED BY SIGNAL: 9 (Killed) ===================================================================================If we switch to openmpi, i.e. we launch the program with the command:
fluent 3d -g -t4 -mpi=openmpithen the program correctly starts.
Could you please explain us which could be the cause of this behavior?
Thanks,
Fabio
January 29, 2024 at 12:23 pm
Rajeshwari Jadhav
Forum Moderator -
May 27, 2024 at 1:58 pm
fabio.dinatale
SubscriberThanks Rajeshwari for the suggestion.
- The topic ‘Error when launching Fluent in parallel mode with Intel MPI on Ubuntu Server’ is closed to new replies.
1891
1419
